New Lighter Tires and Rims + Turbo = Good!
Since i will be gettig bigger tires (DOH) those rims (or another light model) look really nice. I want to get some nice wide 12.5 on the rear but i am not sure how big around yet. the front i will cram the widest tires i can find in there. How big will depend on how much of a lift i end up with.
Thanks for the info and i will indeed post some pics when i get them!
By going with significantly wider rims and tires, you will drastically hurt performance. Not only acceleration but braking and handling as well.
Greedy went with a rim/tire combo that has a larger diameter, but is actually LIGHTER than the stock combination: 22.5 lbs per 5 star limited wheel and 38 lbs/tire average weight in 265/70/16.
Other considerations:
Centerline makes some lightweight wheels.
Rota grids are around 19 lbs for the 16x8. Kevin444 might still have his set for sale.
Pro comp forged 107's - forged, strong, and reasonably priced at stock weight. www.4wheelparts.com might still have the buy 3 get one free deal on these.
i know this is kinda off topic on the tires but will 265/75/16 fit on a factory limited? i have seen people with that size tire but they had some lift or something else under there ride.
and those rims look great on the ride.
Tex,
Thanks for the links and names. I will check those out!
#27
https://www.yotatech.com/forums/f2/t...5vz-fe-114816/
The specs on the wheels are 16x8 - 4.5 backspacing and 0 offset (Model TE37X). They are manufactured by Rays Engineering and come in only white or bronze off the shelf. You can order them in a wide variety of colors for an extra charge. Typically, it takes about 4-6 months to get these once you order them. However, I was lucky and got them used from a guy in cali.
#28
Those are hot, some of the nicest rims I've seen on a runner, I had no idea you could get volks for in a 6lug.
Looks like Rota makes some similar cast replicas too: http://www.rotawheels.com/gridor.php
I might have to look into those.
#29
Yeah - a guy (kevin444) on the forum had(or has) a set of those in silver for sale for pretty cheap. They only weight 18-19 lbs or so and look great!
#30
But those volk's look awesome! we need some driving vids, dude!
#31
Sloan, I am willing to bet that the 265/75/16's will not fit on your 2001 very well. I run them with no lift on my '97 but I believe that the post 1999 trucks sit lower than than those before 2000.
#32
I am running an OME lift front and back and have no rubbing issues. It would be a very tight fit on a stock height ride - even with my 99 coils...
06-01-2021 01:51 PM
09-04-2015 09:27 AM
