YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-07-2008, 07:22 AM   #1 (permalink)
Rock Slide's Avatar
Need Opinions on Polyurethane Body Mounts
I'm looking to get a 1" body lift install soon and thought about replacing the oem rubber bushings with a set of poly ones while I was at it. However, I've heard mix reviews on the poly mounts.
Some owners who have installed a set of the poly bushings complain that b/c the mounts are so stiff, a lot of vibration can now be felt while driving (so much so, that one owner removed his altogether). Others who have installed them said there was no change in ride quality.
I have also read that b/c these poly bushings are so stiff, they do great off road, keeping the body nice and tight to the frame. However, I do a good bit of hwy driving, so any comfort in my current ride I can keep is a plus.
Anyone who's run a set of poly mounts, what has been your experience?
__________________
2002 4Runner Sport 4WD
My 4Runner Profile
Accessories: SS 7.1 Lift Kit, WabFab 1" BL, TJM T15, Stubb Sliders, FX/TSX HID Headlight Retrofit, 1st Gen Roll Bar, Tundra Brake Upgrade, Hilux Surf Field Monitor, TRD I.S. Wheels, Nitto TG 265/75s, Hella HID 4000s, Tint, Black Pearl Emblems, Clear Corners, TRD Decals, JBL Door Speakers
Mods: Disabled DRLs, Disabled Keyless Entry Chirp, Disabled VTRAC/VSC/ABS, Fog Light Mod, Air Elbow Mod, Ashtray Mod, Mud Flap Mod, Rear Diff Breather Mod
Rock Slide is offline
Sponsored Links
To remove this ad, register today!
Old 01-07-2008, 07:36 AM   #2 (permalink)
hross14's Avatar
I have a set--i think there is a little more noise, but not that big of a deal. Just curious--are you using the Roger Brown Lift?
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Old 01-07-2008, 08:09 AM   #3 (permalink)
mjwalfredo's Avatar
Send a message via AIM to mjwalfredo
I got Roger Brown's poly mounts (no lift). I think if my truck was brand new, there probably wouldn't any added noise but since I've got over 200k mi on the odometer I have tired bearings, ujoints, suspension bushings etc. I think the noise these worn out parts make is transferred thru the poly mounts a little bit more. I guess that is a good thing in a way though, you'll definitely know when you need to take your truck in to have something looked at.
Looking back, I probably would have saved my money and stayed with the original mounts. I am not unhappy with them, I just realize now there was nothing really wrong with the original mounts.
__________________
-Marcus
1997 4Runner Limited 4x4, E-Locker, Bilstein HDs, Air Springs, Deckplate Mod, 265/75/16R Bridgestone Deuler A/T Revo
mjwalfredo is offline
Old 01-07-2008, 08:33 AM   #4 (permalink)
Rock Slide's Avatar
Quote:
Am I using the RB Lift...not sure what you mean? I'm currently running the SS 7.1 Lift. I had thought about purchasing the poly mounts from him though.
__________________
My 4Runner Profile
Old 01-07-2008, 09:11 AM   #5 (permalink)
hross14's Avatar
I mean by RB lift--are you running his Body Lift (the UHMW Spacers) and the poly mounts--they are supposed to keep the truck from moving around alot on the frame.
but for all intents and purposes--now that i think back about it--i could have stayed with the original mounts also. If yours are good--then leave them and just add the body lift blocks. My .02
__________________
hross14 is offline
Old 01-07-2008, 09:41 AM   #6 (permalink)
Rock Slide's Avatar
Oh ok...no, I'm not currently running either his BL or his poly spacers. I'll be getting the 1" pucks from WabFab for the BL. We had thought about replacing the body mounts at the same time, but I wanted to get opinions first before I changed my oem ones out.
I'll probably stick with my oem bushings though as long as they're okay.
__________________
My 4Runner Profile
Old 01-07-2008, 11:51 AM   #7 (permalink)
hross14's Avatar
If your OEM bushings are not bad i would keep them.
Just a side note--Are you planning on going 35"s? If so i think you would need the 1 1/2" BL pucks.
Me, i have SS 7.1 and 1.5" RB BL so i can run 35's
That was my understanding anyways
Good luck
__________________
hross14 is offline
Old 01-07-2008, 12:26 PM   #8 (permalink)
Rock Slide's Avatar
Yeah, I still need to get under my truck and check out my oem mounts first. (Some how I keep forgetting to do this everytime I pull in the driveway.)
I just thought I'd get some opinions on the polys ones too though just in case.
No, not planning to run 35's ever. 33's is the largest I want. I'm not doing the BL just for the 33's, but mainly b/c I simply want another 1" of lift
__________________
My 4Runner Profile
Old 01-07-2008, 12:54 PM   #9 (permalink)
hross14's Avatar
fair enough--I was also on the fence between 35's and 33's.....
Good luck with the project--it is pretty easy to do
__________________
hross14 is offline
Old 05-17-2008, 10:20 PM   #10 (permalink)
KZN185W's Avatar
Hi,
I'm planning to replace the stock body mount bushings on my truck with new OEM bushings. The parts have not yet arrived but I'd like to plan on how to do it.
Are there special tools required to do it?
Is there a write-up somewhere on how to replace the body mounts? That would be a big help.
When the old bushing is removed, the gap between the upper and lower mounts might close (i think), how do I deal with that?
Thanks!
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l TRD ATF Cooler l Dual Batteries l Rear LSD l LT285/75R16 l Recaro Seats & Interior Trim
Drive Your Dreams
KZN185W is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Polyurethane body mount bushings? Mad Chemist 95.5-2004 Tacomas & 96-2002 4Runners 19 05-25-2008 06:04 PM
polyurethane bumpstops/engine mounts for a 3.0? 89pickupsr5 86-95 Trucks & 4Runners 4 12-15-2007 05:35 PM
3rd Gen Polyurethane Body Mount Replacements Birdman 95.5-2004 Tacomas & 96-2002 4Runners 4 08-25-2004 03:54 PM
Polyurethane body mounts yotafool 95.5-2004 Tacomas & 96-2002 4Runners 6 08-22-2004 07:01 AM
polyurethane body mounts acid_burn 95.5-2004 Tacomas & 96-2002 4Runners 2 03-14-2003 04:22 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
