need help wiring after engine rebuild
Old 07-18-2003, 06:53 AM
tlwhite's Avatar
I have just finished installing a rebuilt 22-re into my 93 4X4 pickup. Problem is I am finishing up but can't figure out where a wire goes. The wires are three brown wires that come out of the wiring harness under the fuel injection. They are all bundled up with black electrical tape and end in a single lead that looks like it might be ground as a bolt would go through the lead. If it is a ground there is nothing but aluminum in the general vicinity unless I go across to the fender.
Any help with this would be greatly appreciated.
Old 07-18-2003, 07:19 AM
growinseed's Avatar
Do you have any grounds going to head/block to frame? my 22R has three separate ones. Can you find where it is coming from? Just giving you some ideas. Maybe some one with a 93 can help if you have a picture?
HTH
Nathan
Old 07-18-2003, 07:51 AM
r854rnr's Avatar
To me it sounds like you're talking about the ground wire that attaches under the #2 intake rail. There is a steel rod coming from the engine mount to the intake. It goes on the bolt that holds all that together.
Old 07-18-2003, 08:03 AM
tlwhite's Avatar
Thank You very much that is exactly it. I appreciate everyone and the help you were able to provide.
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
steve miller
10-10-2015 01:40 AM
Yota.Jay
07-23-2015 08:08 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: need help wiring after engine rebuild
