Napa TruView Headlights
Old 03-05-2004, 08:25 PM
Chuki's Avatar
Thumbs up Napa TruView Headlights
Well I don't know if you've seen or heard of them... Well I got the oppritunity to get a set of these bad boys.... I like em, they produce a very white light, and have an excellent spotlight effect. They don't bleed out out, where standard halogen kinda run off where they're pointed, and just kinda light these up. These produce a sort of spot where you typically look ahead, and the area around you, is similar to a halogen, but the light is alot whiter in color.
Plus, for you others on the road no need to worry about being blinded, they don't even blind ya like typical halogens. If your in directly front of them where the so called spot is, they're damn bright. But if you have a car or truck there uhmmmm....
Off to the side they don't blind ya, kinda like sideways at a flashlight.
So go to your local napa, if they don't have any tell the counterman they have them at there local DC
Part numbers are your typical sealed beams, and your common capsules followed by a TV
So for us folks that use sealed beams on our yotas'
H6054TV
Other numbers are as follows
9004TV
9005TV
9006TV
9007TV
H4651TV
H4656TV
H6024TV (early gen Yotas Round lights)
H6054TV (Square lights 82-93 pickups and runner)
H6545TV
Like I said the more popular bulbs and beams just a TV at the end of the part number.
Old 03-05-2004, 09:02 PM
ElwayLite's Avatar
Ive been considering silverstars, have you had any experience with the sylvanias to be able to compare the two?
thanks
Old 03-06-2004, 05:30 PM
Chuki's Avatar
No experience with those... All I've had is generic halogens.
One of my lights had a hole in it, and was 1/4 full of water these came in, so I nabbed a set and so far I like em.
Old 03-07-2004, 02:27 AM
Krash's Avatar
How much did they run ya for a pair?
4banginRunner
11-13-2015 05:23 AM
kcaudill
10-10-2015 02:39 PM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Napa TruView Headlights
