my 4runnner feels less powerfull after ISR!
Old 07-15-2003, 02:08 PM
Black4runner97's Avatar
i did the new one from 96 4runner and i have the decplate mod. but when im coming up the mountian it feels more slugish why?!?!?!?!
Old 07-15-2003, 02:14 PM
rimpainter.com's Avatar
Well, did you hook everything up as stated in the write-up?
Check and double check. You should feel a gain. I drove in the mountains (7000ft) and it felt strong as ever.
Did you run premium fuel before installing the mod?
How long have you had it in?
Old 07-15-2003, 02:23 PM
premium? and iv had it in about 2 days. its deffinatly louder but doesnt feel stronger
Old 07-15-2003, 02:25 PM
Are you asking me about premium, or are you stating you have not run premium?
Old 07-15-2003, 02:27 PM
i do not run it. should i?
Old 07-15-2003, 02:43 PM
Yes! While some claim to run regular with no problems, I strongly recommend Premium.
Here is the reason:
On most engines, the ISR mod will cause pinging. Its hard to hear because of the roar. But to the trained ear it will stand out. The knock sensor will then retard the timing to prevent the pinging or even worse - knock. So, by running premium you allow the "flame" to burn longer, creating more complete combustion and thus eliminating timing retard.
I will never run anything less than premium unless I am going to be driving at 4000ft and above for extended periods. In that case, there is no need to run premium. I go with midgrade at higher elevations.
Run premium, and reset the ECU.
Old 07-15-2003, 02:51 PM
prolax13's Avatar
Only run premium if your experiencing pinging. If you have no pinging, then you dont have to worry about it because your air-fuel mixture isnt igniting before the spark plugs fire.
Old 07-15-2003, 03:53 PM
Guest
Yoter's Avatar
Supreme,Ping,ISR,& Power
I was getting the engine ping at take off speed every time when using reg. I went to mid and got it sometimes so went to supreme and good bye. It leaves a hole in my pocket but i hate that ping. I just did the ISR mod today and Poooowwwwwwwwer! It has got to be your fuel so upgrade your fuel and enjoy.
kawazx636
10-06-2021 03:03 PM
Badlander
10-10-2015 08:05 PM
LCE_Performance
10-01-2015 01:03 PM
JookUpVandetti
09-30-2015 08:58 AM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: my 4runnner feels less powerfull after ISR!
