Max power out of a 3.4?
Originally Posted by halcyon0
That seems to be the general concensus from everything that I have found online. Sigh...That just brings up the price...$2k for the SC and another $1k for the fuel mods plus another $1k for the water system (might as well right?) Gonna be lotsa months of eating top Ramen to save up that much cash for it!
You have to consider the whole driveline before you make a decision. There definately is a point you cross where you start grenading drive line parts such as clutch, ring and pinion, axles, and transmission. The engine internals might be strong enough to take 500 HP but if you can't dependably get that power to the ground without trashing driveline parts, it's worthless.
Dependability should be high on your priority list. I like to build things ONCE then have fun with them. You don't want to build a system that is so complicated and sensative that you have to work on it all the time and not have any fun. More than once some of my friends have said "Damn, I wish I would have left it stock!"
My truck makes a little over 300 HP at the wheels that, if you figure a 20% drivetrain loss, is about 380 HP at the crankshaft. I finished "tweaking" it in July of 2005 and haven't touched it since. I get almost 22 MPG on the highway. I have absolutely NO "issues" with the truck. I have hammered the hell out of it during testing with at least 50 dyno runs and at least 10 passes down the strip. WE won't even count all the "ricers" I have done battle with on the street. So far not one failure in the driveline. You can't tell the truck is modded until you nail the throttle. My wife drives the truck with no problem at all. Another plus is that my blower, fuel system, and headers are all CARB legal.
I realize that if I had gone with a turbo system, I would have gotten a lot more HP out of the engine. Sometimes more is not always better.
I did a lot of research and studying before I started my project and I would recommend you do the same. I have a LOT of fun with my truck. I hope when you decide on and build your forced induction setup that you do to.
Thanks!
Thanks for all the great info guys! I really want good reliability and drivability. Something I can drive everyday and not worry about busting something! I think I will keep it mild and go with the motor swap and the TRD SC with URD's fuel system upgrades... I may consider the water injection system some time down the road. Depends on how much my bank account screams!
#25
I would love to know the limits of the 3.4. If this motor is built anything like my 7M-GTE, there's lots of room for power without fear of mechanical failure.
My 430 hp Supra is going up for sale this month, so I see engine modifications in my 4Runner's future. Regardless of which route I go (supercharger or turbo) I'll need a $900 fuel system upgrade. I can drop $2k on the TRD SC or hopefully buy a set of exhaust manifolds and fabricate an adapter to run the Supra CT26 turbo I have sitting at my house. I much prefer the feel (and sound) of a turbo over a supercharger setup. The 3.4 will spool the CT26 even faster than my 3.0 Supra and it pulls full boost by 2200 RPMs.
#26
This guy has lower compression pistons and Crower rods but the rest of the internals are stock. Click on the Tacoma Dyno link to see his 800 RWHP dyno run:
http://www.psiracing.com/videos.html
If you notice, the bed of the truck is loaded down with large truck tires and he is still spinning his tires on the dyno!!
#27
Originally Posted by TRDOLMAN
This guy has lower compression pistons...
So, a quick sidetrack... I always figured that you want to increase compression in order to increase power (since you'd get a bigger bang). What's the theory behind dropping compression? More room for more mixture?
#28
I honestly believe that the 3.4 is capable of the same types of HP gains that they got out of the Supra motors. Toyota has always overbuilt and undertuned their motors for reliability. I think that the latest efforts by the import tuning community are just now starting to see what it can do. I bet we see a close to a 1000hp 3.4 one of these days. We have seen some twin turbo setups on the 3.4 that have not been dyno'ed. Can't wait to see where this all goes.
#29
Originally Posted by midiwall
{holy bajeezus!}
#30
I don't know the proper terms to explain it properly but if you lower the compression you can up the boost pressure giving you more actual compression (wrong terms but I don't know the right ones). Lowering the compression lets you add more boost without increasing the detonation factor which lets you add in more timing. I'm sure one of the "boost gurus" will chime in and supply the right terms.
Thanks Dave!
#31
Max power
I know that the guys over at URD have built a 800hp truck with twin turbochargers. That will put a grin on your face and make your bank account scream for mercy!
#32
https://www.yotatech.com/forums/show...5&postcount=13
https://www.yotatech.com/forums/show...3&postcount=14
#33
Flying91
45
04-11-2024 04:39 PM
Backcountry411
07-24-2015 08:06 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
