low idle, 3rd generation
Old 11-01-2005, 06:31 PM
BeMiceElf's Avatar
alrighty, here is my current problem. my 99 4runner will run fine wile driving down the road but when i am at a red light or just sitting somewhere i have noticed that it idle kind of rough, at about 500 rpms, and sometimes when i start it up it will idle really, really low and then cut off, but then it will start of fine the next time if i just give it a little gas when i start it up. this just does not happen when it is cold, it has happen right after i have cut it off then back on again. ooh, it seems to idle rough mostly in gear and not in park. this may sound a bit confusing, but i have no clue what the problem is so any info would be most helpful.
thanks
Old 11-01-2005, 06:53 PM
Bob_98SR5's Avatar
what was your last set of maintenance items? when was the last time you changed the plugs?
bob
Old 11-01-2005, 07:26 PM
noahrexion's Avatar
you should try kicking the idle up a bit, by adjusting your TB screw (IAC)
Old 11-02-2005, 06:17 AM
MTL_4runner's Avatar
No way to adjust that on a 3rd gen.
You should follow all 5 pages of this maintenance guide (if you haven't already):
http://www.4x4wire.com/toyota/mainte...30k/index.html
If you still have problems, post back.
Old 11-03-2005, 02:02 PM
BeMiceElf's Avatar
thanks for the info
Old 11-03-2005, 02:17 PM
TxDox21's Avatar
What should the 3.4L 3rd gen idle at?
Old 11-03-2005, 04:07 PM
dobber's Avatar
I've had similar problem with my 97 runner and it was the idle control valve.I've also heard of maf sensor dirty on vehicles running oiled filters such as k&n type.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: low idle, 3rd generation
