| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Loading New Winch
__________________
96 Runner SR5, 4x4 97 Volvo 850 GLT "Rice Killer" |
#2 (permalink) |
Guest
I dont think you have to do that... Only pain in the butt part about a winch
, is not letting the cable getting all messed up...
#3 (permalink) |
If you read the owners manual for your winch it says to unspool all the cable & respool under a slight load.
#4 (permalink) |
The line isn't initially wrapped under any load, so if you were to use it straight up, I could imagine that once under load, a coil from an outer layer of line could slip in between underlying coils when winching under load. You would then run into trouble trying to spool out line due to this. This is my guess anyways. Either respool like you've suggested using the pole, or do it by hand pulling on the line, should probably be enough to do the trick.
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
#5 (permalink) |
Staff
Rewinding under load does help prevent the outer wrap pulling under a lower wrap.
Do it with the pole like you said. I did mine by winching up a slight incline so I didn't have to use the brake.
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Weird stuf after loading Internet Explorer 7 | UKMyers | Computer Talk | 17 | 02-20-2007 06:43 AM |
| Loading 1600lbs. in bed of pickup truck. Need help fast! | jethro | Off Topic Talk | 13 | 04-07-2006 03:10 PM |
| Pre loading Toyota strait axle knuckle bearings | YO38 | 84-85 Trucks & 4Runners | 3 | 03-09-2006 01:40 PM |
| MSFT Movie Maker: Loading music | rimpainter.com | Computer Talk | 0 | 01-11-2005 11:22 AM |
| Down loading pictures | JASPER99 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-29-2004 09:51 AM |
