| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Lights on Roof Rack
__________________
2002 4runner |
#2 (permalink) |
i got some kc daylighters from summitracing for around 75$ for a pair of em.
__________________
95 SR5 4x4 4runner Sony Xploid cd player(not sure which one) Rockford fosgate 900 watt 2 channel amp, 2 600 watt kenwood 10 inch subs. Some cheap cb from walmart Surco safari rack with 2 KC Daylighters 15x8 tech 1 rock crawlers Spintech exaust external fuse box mod. Airbox MOD. K@N Air Filter. ISR MOD Downey HD's |
#3 (permalink) |
Any driving or long range lights would work up there.
PIAA Hella IPF Lightforce Warn KC And many others. You can go to ANY web retailer of 4WD products and search for lighting and find more choices than you'll know what to do with. Lastly, do a on roof rack lighting. This subject comes up quite a bit.The search button is your friend.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#4 (permalink) |
hella 500s are solid at about 70 bux a pair. like cebby said, check out websites for 4wd's. in this instance, google is your friend...
#5 (permalink) |
Senior Member
As said, any type of long range light will work well up there. I've got 4 Hella 500s on my rack, and I love them. However, I think 2 500s tend to look like mickey mouse ears. IMO, if you're going with 2 lights, go with rectangular ones, not round ones. The rectangular version of the Hella 500 is the Hella 550. IMO, Hella gives you the best bang for your buck - good performance, good build quality, good price. I get most of my stuff from 4x4connection.com. They are located in Va, so shipping to the east coast (where I live) is a lot faster than from CA.
__________________
Jackson - My Site 96 SR5 4x4 - 33" MTs, open diffs, and 3.90s - LET'S ROCK! My runner has bee traded in *sniff* on an 06 SR5 long bed d-cab Tacoma. The tacoma is nice, but... *sniff* ... I'll update my site when I'm done grieving. |
#6 (permalink) |
What rack do you have? Like Jack Ive got 4 500 (driving) and they are great. There are several mounting options, that why i ask what rack you have. If you have the load worrior, if you get the yakima light mounts you can fit the hella 550s (the square ones) under the mount. They fit behind the farring and will not effect your milage anymore than its already ruined. Not to mention make less noise. But if you don't have a yakima... forget what I just said!
#7 (permalink) |
I have a Con-Ferr rack. From what everyone says the Hella 500's are the way to go. I dont really understand the difference between the driving and fog ones, but I'll just get the driving one.
Thanks a lot for everyone help.
__________________
2002 4runner |
#8 (permalink) |
to sum it up...driving lights go farther and the beem is more narrow. fogs cover a wider area, but dont go as far. ( i think)
#9 (permalink) |
Senior Member
Doink is basically right. Driving lights are kind of like highbeams. They throw a longer beam to lightup the road ahead. But the beam is very narrow, so they aren't much help lighting up the sides of the road. They are generally meant to be used in good weather, when you are the only one on the road, at relatively high speeds. Fog lights are meant to be used to supplement your low beam lights. They offer a very short, very wide beam, and are meant to be mounted low so they reflect less off of bad weather (rain, snow, fog, etc).
Basically, if you want lights to help you in the bad weather, get fogs, and mount them as low as possible. If you want lights to help you see down the road, get driving lights and mount them anywhere. If you want more light on the trail at night, get fog lights and mount them to the sides of the rack and mount them down, so they shine very close the rig/trail. I only know one or two people who have done this (aux lights on the trail are hard to use without blinding everyone else on the trail).
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| lights on stock roof rack | lee | 95.5-2004 Tacomas & 96-2002 4Runners | 47 | 10-28-2005 05:00 AM |
| Mounting lights on roof rack?? | ugabulldog | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 06-14-2005 12:33 PM |
| Picture with High-Lift / Roof Rack / Roof Lights , Finished | Breezey | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-30-2004 09:43 AM |
| Roof Rack Lights | Ducky | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 07-30-2003 12:23 PM |
