leaky rad fitting, any fixes??
Old 06-24-2010, 05:36 PM
y2kltdsport's Avatar
Hey guys, got a y2k runner 240K miles, did the tranny bypass last summer, and you know where you connect the pc of hose between the cooler inlet/outlets at bottom of rad, well the drivers side fitting is kind of loose, meaning I can easily turn it a bit by hand, that is where the leak is coming from, where it threads into the rad,any ideas?? anyone had this issue, would like to fix it instead of replace rad right now, tried a bit of jb weld, worked a little ,for a while but the weeping fluid would not let the jb stick well, should I drain rad and clean area and try another method of sealent epoxy etc?? any help wouild be awesome thanks Mike
Old 06-24-2010, 06:55 PM
any other ideas???
Old 06-25-2010, 06:05 AM
anyone????????????
Old 06-25-2010, 06:44 AM
Qyota's Avatar
Drain it, fix it (epoxy, JB, whatever works), fill it. That's the cheap way. The other way is to buy a new radiator.
I thought there were certain epoxies that worked when wet?
Old 06-25-2010, 06:50 AM
I just need a temp fix while I decide on a radiator, any suggestions?? any input on the koyos??
Old 06-25-2010, 09:24 AM
o2raybid
09-04-2015 12:45 PM
WellsR
12
07-31-2015 03:27 PM
TDonkey
07-26-2015 10:14 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
dinks07
07-15-2015 05:34 PM
Quick Reply: leaky rad fitting, any fixes??
