leaf spring centering bolt???
Old 05-07-2006, 06:11 PM
richboss302's Avatar
Question leaf spring centering bolt???
I want to remove the 1 inch helper/add-a-leaf spring and the top of the bolt that sticks/drops down through the leafs is ROUND. How do I remove the nut on the bottom of the bolt on the underside of the leaf spring without the bolt spinning/turning as I try to loosen the nut??????? Do I have to use vise-grips or something simular?? The head of the bolt is not hex shaped like a normal bolt, it's round??
Thx,
Rich
Holiday, Florida
Old 05-07-2006, 06:25 PM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
vice grips.
if worse comes to worse you can file some flat edges on and use an adjustable crescent wrench
nvdesertrunner
05-11-2020 08:18 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
shisha1999
09-21-2015 08:22 PM
88sasturbotoy
08-11-2015 01:56 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: leaf spring centering bolt???
