LC Engineering Header?
Old Nov 21, 2005 | 08:43 PM
90FFyota's Avatar
Hi all, I had a question regarding a lc header for my 1990 pickup 4x4 reg cab with a 22RE. On lc's web site the only application I can find is a header for a 22R, will this header work with the 22RE? Thanks for the help.
Old Nov 21, 2005 | 09:16 PM
90FFyota's Avatar
Any takers?
Old Nov 21, 2005 | 09:36 PM
midiwall's Avatar
Did you try dropping an email to them, or calling them? You could probably even use the 800 # for the order line and ask them.
http://lcengineering.com/
Old Nov 22, 2005 | 12:25 AM
Elton's Avatar
22r header will fit as i have one on my truck also do a search
Old Nov 22, 2005 | 01:09 AM
bob200587's Avatar
I think you actually have to have a plug to use it with the 22r. It does have the spot for the O2 sensor, and I think thats the only difference.
Old Nov 22, 2005 | 01:12 AM
Elton's Avatar
i guess some come with spots for the o2 sensor mine didint have one just the one down by the cat
Old Nov 22, 2005 | 01:18 AM
bob200587's Avatar
A guy I know has a 22r and his LC header came with the O2 sensor hole. It also came with a plug of sorts if you didn't have the fuel injected motor. I'd hope the things were consistent.
Old Nov 22, 2005 | 08:55 AM
03_4x4Runner's Avatar
like said above, just shoot them an e-mail or a call, they should be able to answer any questions you have.
Old Nov 22, 2005 | 09:53 AM
Elton's Avatar
yep just give them a call there really nice there
Old Nov 22, 2005 | 03:35 PM
Fahrenheit 451's Avatar
The early headers came with the o2 bung in the #3 primary, but since this tended to cause issues with CELs getting thrown from inaccurate readings they changed over to locating it down just before the cat.
I have an old set that I hate for the noise, but they have given me good service otherwise. The newer versions are also a thicker gauge metal so they will be a bit quieter under the hood.
Old Nov 22, 2005 | 03:39 PM
90FFyota's Avatar
Thanks for all the help guys, I contacted LC today and my header should be here by Monday.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Sep 4, 2015 09:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Coreyr384
Jul 10, 2015 11:13 AM
