KZN185 rear door latch not working
Any one had this problem?? The door is closed at the moment, it won't open so how do I get access inside the door to see whats wrong?? Any help appreciated. Does anyone have an exploded view of the door I can have a look at?
Cheers, Dan
Cheers, Dan
either way it is the same if it is the rear hatch or the back door. I am guessing it is the rear hatch since a rear door has two handles (one in and one out). The panel needs to be removed. If it is the rear hatch there is a bolt under the cover where the pull strap comes down. One of linkage arms probably popped off.
cchinny
06-25-2015 08:11 PM
