Knock sensor bypass question
Old 01-30-2015, 12:40 PM
Brino83's Avatar
Just bought a 98 limited with the 3.4 and its throwing a PO330 code.ive spent a couple hours searching/reading threads on here.I need to get it to pass inspection ASAP.From what I've read on here there is a way to bypass the bad sensor/harness using the other good sensor however I cant seem to find anything as to where the drivers side bank KS wires run into the ECM harness so that it can be temporarily bypassed.Any info is appreciated.Thanks!!
Old 01-31-2015, 07:30 AM
Brino83's Avatar
Anyone?
Old 02-01-2015, 12:47 AM
wyoming9's Avatar
Red face
Why not fix it??
With all this research no ones shows just how to do this if it will even work interesting.
Old 02-01-2015, 06:04 AM
habanero's Avatar
Interesting reading, pics, a link, that may help you....
https://www.yotatech.com/forums/f2/c...30-saga-56080/
Also have seen some interesting stuff with Radio Shack piezoelectric sensors, but I'm assuming if you don't have time for the actual fix at the moment (and it's often simply the wiring harness, WHY does it have to be so inaccessible???) you won't have time to figure that out, either....
if you've got something really happening that the knock sensors are picking up you want to figure that out rather than simply bypassing and leaving it. Retarded timing, gas guzzling, and gutless driving isn't a good thing.
Old 02-01-2015, 07:22 AM
Brino83's Avatar
I just bought it Wednesday.The images on that link won't pull up for me.Its going for timing belt,water pump,tensioner and valve cover gaskets in 2 weeks that's when I'll have both knock sensor harnesses replaced.I need it to pass inspection before that though.
Old 08-11-2017, 03:23 PM
4runnertrdpro's Avatar
Bypass po330 knock sensor code
Right above the 4 cam letters behind the timing cover you will see a connector that runs right over the top of the coolant piping. Disconnect the connector. Peel down the insulation that's covering up the three lines. One should be black, one should be grey and then the last one is orange. Cut a section off of the black and the grey lines and wrap them together and soder them.. finally wrap the grey and orange lines with electrical tape. Plug the connector back in. And boom your done.
Just remember soder the black and grey line together not the orange
Old 08-11-2017, 04:05 PM
old87yota's Avatar
Originally Posted by 4runnertrdpro
Right above the 4 cam letters behind the timing cover you will see a connector that runs right over the top of the coolant piping. Disconnect the connector. Peel down the insulation that's covering up the three lines. One should be black, one should be grey and then the last one is orange. Cut a section off of the black and the grey lines and wrap them together and solder them.. finally wrap the grey and orange lines with electrical tape. Plug the connector back in. And boom your done.
Just remember solder the black and grey line together not the orange
Or you could actually fix the problem...
Old 08-12-2017, 01:53 PM
ksti's Avatar
Old post, the OP moved on.
Last edited by ksti; 08-12-2017 at 01:59 PM. Reason: old post dude moved on.......
the1998sr5
15
07-14-2020 08:35 PM
tj884Rdlx
08-28-2015 12:04 PM
nonstop
07-24-2015 06:29 PM
88yodabasket
07-13-2015 01:32 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Knock sensor bypass question
