Installing front shock/coil assembly
Old 10-16-2015, 12:36 PM
83's Avatar
Almost done...and a bit more of a pain than I expected. I've run into this on the driver side. Is this within what's normal, and I just need to work the bolt in there? It absolutely has no wiggle room. It's completely solid in the position it's in. Doesn't seem like it'll straighten out.
The other side when in just fine (more or less), but I'm wondering if the shop who swapped the coils for me got this one off-center? Or do they only go in one way?
I've tried lining the whole assembly up every different way, and this is the only way that is even close to lining up.
Any help?
Old 10-16-2015, 01:07 PM
83's Avatar
Old 10-16-2015, 02:48 PM
83's Avatar
Nevermind...
If anyone else reads this who is as inexperienced as me: The shock actually spins inside the coil. I took it off the truck completely, then stuck the bottom end in the mount. Once it was in the mount, lined up, I spun the top of the shock till it looked like the three bolts would line up.
Took it back out of the bottom, bolted it into the top, and the bottom slid right in, lined up just right.
Ugh.
Old 10-17-2015, 12:34 AM
wyoming9's Avatar
Red face
I was going to tell you to just twist the eye on the shock.
Live and learn
Glad you figured it out.
Old 10-17-2015, 04:57 AM
83's Avatar
Yeah, thanks. It wouldn't spin at all from the bottom. Once the upper mount was in, the lower eye wouldn't move a cm. But with the lower mount secured, the top would rotate.
So yeah...now I know.
Next up, lower ball joints.
Old 10-17-2015, 07:04 AM
wyoming9's Avatar
Red face
Doing this just now all 3 of the top bolts broke loose I could cut two off with a zip disc but the third no way can I get to the bolt.
A little bit at a time with the dye grinder and a Carbide burr.
None of the cotter pins came out of the ball joints
Such is my life at times.
Old 10-17-2015, 04:59 PM
83's Avatar
It helps to be in the arid west. That and PB Blaster a few days before made getting bolts out the easy part...
Old 10-17-2015, 11:37 PM
wyoming9's Avatar
Red face
Mine were soaked in Kroil on and off the last 2 weeks.
Now I got the Monroe ones and with the top one nut holding it from falling out I could turn the bottom go figure .
Old 10-18-2015, 04:58 AM
83's Avatar
That makes sense, I think. I couldn't turn the bottom at all with the three top bolts secured into the mount. But once I took those out, it would spin. I'm sure the bottom could move, too. I just had the bottom in the lower mount when I tried turning it, since I was lining up the top bolts.
Once I get the lower ball joints done (hopefully today), I'll be able to actually drive it around and see how it feels.
mistershmi
01-05-2016 11:07 AM
Longbed 90
10-19-2015 11:05 AM
I8URSVT
10-05-2015 07:23 PM
I8URSVT
10-05-2015 05:42 PM
JookUpVandetti
09-24-2015 08:56 AM
Quick Reply: Installing front shock/coil assembly
