installed a new fuel filter; made a huge improvement
I installed a new fuel filter in my 4runner today and, wow, the idling is right back to 700rpm. I can't believe how a new fuel filter made a huge improvement. I thought it was dirty throttle body but my guts tell me it was fuel filter. Now the engine is running smoothly on idle.
The problem I noticed was the rpm bounce up and down on idle (700-900rpm) and sometime idle stuck at 900 rpm while idling. And also, I put cruise control on freeway and it does bogging on freeway for a split second.
Just wanted to share with this with you even if you have similar symptoms what I had on my 4runner. Hope this helps.
It does puzzle me how Toyota can say this never should be replaced; it is a lifetime part?.....
4 years or 60,000 miles has always been a good rule of thumb for me for a fuel filter replacement.
Here are some threads I found useful. I haven't attempted the fuel filter replacement yet, but I plan to in the next year.
I changed the fuel filter on my 4Runner today
3rd gen Runner fuel filter changeout
"Not-So-Lifetime" 3rd Gen Fuel Filter
No you don't need to drain the fuel tank. I just took old filter off and new filter in 15 mins. Then turn ignition on(not start the engine) for about 1 min, letting fuel pump doing it because you lose gas in the line. Then start the engine on. Its easy as a b c.
Hope you are kidding. Redline is at 5,500rpm. lol
so hopefully this link works as an external link, but while lookin to price the fuel filter, I found that there is also another filter for the fuel pump itself inside the tank. Any idea if those get clogged/dirty too? I only imagine the inline filter being dirty after it passes through the one in the tank first...
http://www.toyotapartszone.com/Page_...reName=MAJ667A
hahaha......
Fuel filter and rack bushing kit are the two things inline for me to do before winter. I've got a different car in the garage to rebuild the head, hone the bores, re-ring and replace bearings on. Trying to get that done asap, so we can sell the darn thing.
I've been running Nippon filters, not really sure of the difference between the NipponDenso product line, but they are a bit cheaper and include the bracket
My 4runner is right now 131,000kms (81,400 miles). I'd say about 75,000 miles that fuel filter went bad. It was original fuel filter.
My gas mileage improved noticeably. I haven't calculated how much better mpg I got now, probably increase 2-3mpg or so. I can't remember when last time the engine run so smooth but I love my 4runner more than ever now A bit more power as well.
It's more of a strainer to keep larger particles out of the pump. Mine was still in very good shape so I left it when I changed my fuel pump.
