Inner Tie rod / rack end?
Old 07-07-2005, 07:05 AM
Senior Member
data's Avatar
Are these the same thing? I'm getting quoted different prices. The dealership said I needed my inner tie rods replaced because they could not give me an alignment. Does anyone know if this is the right part number?
45046-39335
45047-39215
Because I called my local dealer here and he only gave me this part number
45503-3907
Old 07-07-2005, 07:30 AM
Crux's Avatar
Originally Posted by data
45046-39335
45047-39215
These two part numbers are for the outer tie rod.
Old 07-07-2005, 08:05 AM
Senior Member
data's Avatar
wtf...the lady at toyotaparts4u said these were the inners. Do you have the inner part number? Check it out...
Hello!
Here is a quote on the inner tie rod ends, also 2 nuts that go on the part that go into the steering gear rack, you may not need them though.
90170-20003 NUT, HEXA 0.94 each x 2
45046-39335 END SUB-A 40.78 1
45047-39215 END SUB-A 40.78 1
SHIPPING $12.00
TOTAL $95.44
Old 07-07-2005, 11:12 AM
Crux's Avatar
Goto www.1sttoyotaparts.com and type in the part number in their search.
45046-39335 & 45047-39215 both come back as outer tie rod ends (left and right).
I'm not sure what the part # is for the inner tie rod (or 'rack end') but if you search for the key words "inner tie rod" it comes back at $99.18 (note: the part is the same for both left and right sides)
09-04-2015 09:27 AM
Shaun Crystal Gomban
08-02-2015 08:00 PM
ahriman
08-01-2015 10:38 AM
krimsonone
07-29-2015 11:53 AM
ripp96
07-25-2015 02:32 PM
Quick Reply: Inner Tie rod / rack end?
