| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ideas needed for adding extra switches
__________________
1992 "Truck" 1978 Land Cruiser FJ40 pig and elephant DNA just won't splice :( ***DO NOT CLICK HERE*** |
#2 (permalink) |
Sponsoring Member
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#3 (permalink) |
If you have places to put coins in your center console, you can pop othose out and replace them with a switch, thats what i did
__________________
Go Dawgs!! |
#4 (permalink) |
yea use the empty slots.....that what they were made for. those painless boxes are nice but are probably pricy and could be made easily and much cheaper with the led switches and everything
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008) 2006 Mazda3 GT 2000 TRD Tacoma..Bought back and crushed 1988 4Runner SR5 V6 5 speed..sold |
#5 (permalink) | |
Quote:
__________________
#6 (permalink) |
haha oops....well i guess a trip to radioshack is in order to pick up a project box and some switches...and some double stick tape to stick it somewhere convient...i dont want to see any duct taped switches anywhere...altough that would be nice for an ultra convient switch
__________________
#7 (permalink) |
any other ideas?
__________________
#8 (permalink) | |
Quote:
__________________
Ironpig2 is a 1990 4runner SR5 95 3.0V6, ARB front bumper, Hella H4 conversion, Hayden Trans cooler, Aisin manual hubs, Drilled headlight bezel, Clinometer, Altimiter, Assorted Camera mounts, JVC double din head unit, Hilux Surf emblems, Bridgestone Revo's, OME 901's , N72f's "Stay calm, Be brave, Wait for the signs." |
#9 (permalink) |
yes please. how much? hey, would you be interested in trading your ARB bumper for a new pair of lightforce 170s + cash?
__________________
#10 (permalink) | |
Quote:
__________________
--Miles Sold '91 4runner, 22re, 5 spd manual, 180,000 miles, cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods: My 4runner page My 2006 Camry page I'm a Myspace Addict! |
#11 (permalink) |
i'm sure it would but i have no experience in buying or using any sort of material like that. although i'm pretty sure i could get access to the equipment to work with it.
__________________
#12 (permalink) |
still clueless on how to make this work...
__________________
#13 (permalink) |
I say drill some holes left of the steering wheel. Worst come to worst, you will have some new air vents
. It shouldn't be to hard at all, just gotta get the nerve. does your truck have a clock? If not then you could mount some switches in there. Thats what I did. Ill snap a pic for ya tomorrow.
__________________
92 pickup... sold 90 integra- b18b turbo, intercooled, 10 lbs of boost, 240 whp... blown up 79 2wd yota pickup |
#14 (permalink) |
sizzle,
can you take a pic so we can see what youre talking about? bob |
#15 (permalink) |
You could do something like this under the deck...wouldn't be too hard just cut a piece of plastic to fit then drill holes in it.
__________________
-Geoff *1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi. |
#16 (permalink) |
oops, just noticed when re reading it that you're looking for switches not gauges...my bad, oh well you could do the same thing with switches just cut smaller holes
__________________
#17 (permalink) | |
Quote:
![]() here's what i'm working with...
__________________
#18 (permalink) |
Going through the EXACT delema at the moment!!!!!!! So far I have pulled the lower dash and there is very little room behind that panel to the left(I have air and the duct runs behind there as well as the support for the steering column) Best you can do is 1 maybe 2 above the clutch start and the dimmer switch. I have an eLocker and the switch for that is below the 4way flasher switch. I found the locker control switch from a FJ80 has a very shallow mounting depth...........SO far 1 switch above the clutch switch, the FJ80 locker switch next to that and *BAM* 3 switches taken care of.(yes I said 3,,the FJ80 switch has provisions for RR and RR/FR so when I add the ARB to the front I'll be set)
Now my next project.....Owned a Subi once and I remembered it had the 4way flasher switch on top of the steering column.....ok so now I have to go to the J/Y. once thats done it will open 2 holes for switches. If I use DPDT switches in those holes I figure I can control up to 4 sets of lights w/ 2 switches!!!!!!!!!!!!!!! The one over the clutch switch I'll use to "arm" my winch. Should look very clean when done. *edit* I'm planning to use the space under the HU for my 2m radio. so no switch pannel can go there. Jake. Last edited by Jake94; 04-08-2005 at 12:28 AM. |
#19 (permalink) |
here's the corrected link from way up on top that doesn't go anywhere. http://www.painlessperformance.com/w...t-switchcc.htm
__________________
'95 Xtra cab 3VZE SR5V6 | 33x10.50-15 BFG AT/KOs | 4" Superlift | OME torsion bars | Total Chaos idler arm and uniball | Rancho steering stabilizer | Smittybilt front & rear tubular bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console sometime: rear locker some sometime: retire the IFS My truck page Photography: http://www.aspen-graphics.com |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Adding Extra Accessory Outlets - 3rd Gen 4Runner | Bob_98SR5 | Electrical | 0 | 12-31-2005 08:23 PM |
| Costume Ideas Needed | AznSky | Off Topic Talk | 9 | 10-10-2005 04:46 AM |
| anyone got ideas for extra din space below head unit... | Amir904 | 95.5-2004 Tacomas & 96-2002 4Runners | 26 | 04-26-2005 05:16 AM |
| need some ideas on mounting some switches and gages in an 84 PU | slider_buck | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-07-2005 04:28 AM |
| TOO MANY SWITCHES!! Any custom ideas? | yoda-g2 | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 02-21-2003 11:42 AM |
