I want higher wattage headlight bulbs . . .
Old Nov 17, 2004 | 07:16 AM
Ben03's Avatar
. . . how high can I go, I'm thinking 80 W low and 100 W high, has anyone gone this way with a Tundra or similar headlamp setup?
Also, with the Tundra foglights, what kind of bulb is in there and can I get an amber/yellow bulb?
I post on the Tundra site but get no replies, thanks.
Old Nov 17, 2004 | 07:31 AM
ranma21's Avatar
I am running HELLA 80/100 now and it is obviously brighter than stock. I rewire just to make sur eI would not melt the stock wire. Highly recommend!!
Old Nov 17, 2004 | 08:28 AM
Ben03's Avatar
You have no problem with your housing or lens, right? And also, if I didn't change my wiring, would I be ok?
Can I just go to my AutoZone and order the Hella's?, as I don't like ordering anything online, how did you get yours? I like the Hella name and love the idea of 80/100's, I'm not a believer in those Silverstars or any of those other kinds of bulbs with coatings, coatings reduce output, I want a clear bulb with higher wattage but don't want to melt my housing/lens or screw up my wiring.
Old Nov 17, 2004 | 08:33 AM
obex26's Avatar
If you want brighter head lights run a second battary might be easier and cheaper then trying to rewire the existing. And I have had the same headlights since I bought the truck 3 years ago. Basically with dual batteries it makes your low beams equivalent to your high beams and your high beams alot brighter. Best part is if and when you sell your current toy for a replacement nothing in the wiring has been altered and its easy to remove the second battery setup with out permanent modifications to the vehicle.
Old Nov 17, 2004 | 09:17 AM
2001Millrunner's Avatar
if you have plastic housing I'd stay away from high wattage bulbs. Battery is another issue but your reflective lenses will most likely becom fussy overtime due to high heat situation, especially the upper part, right above the bulb. Why not get seperate driving lights?
Old Nov 17, 2004 | 09:21 AM
ranma21's Avatar
Of coz you can order from Autozone. I got really cheap deal by ordering online, like $4 a piece of HELLA 80/100. My lens and housing are perfectly fine. I think you should be all right with your stock wire. Do not quote me on that, I actually did not alter my wire but simply run thicker wire ( eg, 10 gauge that will allow better current flow ) and add relays to it so the power is drawn directly from the battery instead of the stock wiring. The stock wire is just act like a switch through the relay. Just like you said, I tried all kind of bulb before (silverstar and all the blue or white bulb) and those are junk compare to true high out put halogen bulb except real HID. My advise is to run a thicker wire to maximize the flow of the current ( actually brighter ) and most importantly to avoid wire melting problem. Good luck!!
Old Nov 17, 2004 | 07:01 PM
BruceTS's Avatar
I installed a HD wiring kit with 2 relays, I then was able to use 130/90 bulbs without any problems......
4banginRunner
Nov 13, 2015 05:23 AM
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
