I need some help with defining a noise
My vehicle is a 1992 4runner 3.0 V6 4x4 w/ a manual tranny. It has 187,800 miles on it and is making a noise that I believe is coming somewhere from the front axle. I took it to a mechanic when it started making the noise more frequently and they said it was the differential bearing. They fixed that with fixing IFS coponents and replacing the breaks. The noise never seemed to go away but it seemed to get better after they worked on it. Now its been a little longer then a month and it seems that it is getting in the same condition, however it only does the noise when the vehicle is cold and expecially when the weather is cold outside. The noise is a low grumbling noise that u can feel in the steering wheel and pedals coming from that area of the vehicle. If anyone had the same problem or know what it might be please leave me a message.
Thanks
Logan
Thanks
Logan
does it make the noise when things are cold? does it eventually go away after the front drive components warm up? it could be the bronze bushing in the knuckle wearing out. the good news is, there is a repair option for this. replacing the bronze bushing with needle bearings et al. seach for front end wheel bearing or similar and you should get lots of reading.
lee
lee
Definately sounds like the wheel bearing. My runner is doing the same thing at the moment. I've got to replace my bearings this weekend when I switch to manual hubs. Do a search there are many good threads about this on the board.
lee
lee
Hmm, looks like I got 6 to 20 hours of work ahead of me depending on how fast I am and weather or not I decide to do both sides. Here it the writeup:
https://www.yotatech.com/~corey/tech...imrockford.htm
Location: Far western Kentucky (transplanted from central PA)
I had that on my '90 and Toyota told me the same thing. It wouldn't hurt anything but the fix was a bit expensive. It really bothered me but I could usually get it to go away by shifting into and out of 4WD.
Originally Posted by bike4miles
I'm going to do the wheel bearings and possably do a hub swap if I can get my hands on a set.
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
