I found the problem
Old 03-28-2005, 02:52 PM
trx125's Avatar
I found the problem
It died because the pickup coil came apart inside the distributor. When I pulled the cap off there was shredded fine copper wire around the distributor shaft the windings in the pickup coil came out of the assembly. Has this ever happened to anyone? Is this common or is there some other underlying problem? Thanks for reading and any advice you have?
rushw
07-18-2015 01:46 PM
msane99
07-17-2015 10:13 AM
icentropy
07-14-2015 10:23 AM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: I found the problem
