hubs engaged/free?
Old 08-27-2005, 02:44 PM
supahonkey's Avatar
hubs engaged/free?
A friend asked me today why he can't simply keep is hubs engaged, and control 4x4/2x4 from the transfer case. I didn't know, so I couldn't give him an answer. If the hubs are locked, but the transfer case is in 2x4, then the axle shafts, R&P, and driveshaft will spin, but the t-case won't... so what's the problem with keeping the hubs engaged?
Old 08-27-2005, 03:35 PM
garrett1478's Avatar
keeping hubs locked causes more wear and tear on the cv boots and other parts of the front drivetrain
Old 08-27-2005, 03:39 PM
YeloSub7's Avatar
but thats what happens when u have auto hubs? so keeping your manual hubs locked is just like having auto hubs right?
Old 08-27-2005, 03:47 PM
leebee's Avatar
yes, that is correct. you have the option of unlocking the hubs to lessen the wear and tear on the front end parts. once you start replacing cv shafts etc, you will definately appreciate being able to drive unlocked!
lee
Old 08-27-2005, 03:49 PM
EWAYota's Avatar
heres a good thread for you to read, it'll answer all your questions
https://www.yotatech.com/forums/show...g+hubs+engaged
Old 08-27-2005, 04:11 PM
YeloSub7's Avatar
basically with auto hubs your kinda screwed... and your stuff will wear faster whether you like it or not...
Old 08-27-2005, 04:41 PM
javadoody's Avatar
not to mention the gas mileage. huge difference.
unless you swap them out with manual hubs
Old 08-27-2005, 04:44 PM
YeloSub7's Avatar
well ya, exactly...
Old 08-27-2005, 09:32 PM
4Crawler's Avatar
Auto hubs lock and unlock automatically. Auto hubs are normally unlocked until you stop, engage 4WD and then apply torque to the front axle shafts and that locks the hubs. Then they stay locked until you use reverse, when they unlock.
http://www.4x4wire.com/toyota/tech/autohub/
But it is OK to lock the manual hubs and use the t-case to select 2WD and 4WD as needed. Done it many times, very handy to use when you have stretches of snow/ice then bare pavement, just flick the t-case lever back and forth as needed.
Old 08-27-2005, 10:01 PM
Nick Cuban's Avatar
so do all tacos that you can not lock or unlock have ADD or do they actuallly disengage at some point? im confused and i read that link... didnt help
Old 08-27-2005, 10:22 PM
4Crawler's Avatar
Autohubs were only used on some of the early trucks, I think only through the '80s. After that is was ADD or manual hubs. ADD leaves both axles permanently locked to the hubs, but the differential is disconnected on one side to allow the front end to free wheel:
http://www.off-road.com/toyota/tech/add/index.htm
ladybugRC
458
08-21-2020 10:41 AM
G-off
12-29-2015 12:44 PM
AaronM
12
11-04-2015 04:06 PM
stanz
10-30-2015 10:33 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: hubs engaged/free?
