Hows this setup?
Old 08-12-2007, 07:05 PM
Nate08's Avatar
Hows this setup?
Well...after 3 weeks with my Tundra/OME lift, I am already deciding on my next "big move". I want to clear 285/75's without a body lift or any rubbing at all; or very very minimally. So this is my thought:
1. Keep Tundra coils and Trek's and add a 1" Cornfed spacer.
2. Get LC coils and shocks for rear.
3. Extended Panhard bar.
4. Extended Brake Line.
5. Diff. drop.
Its pretty much a SS system, but I'm not looking to pay $1200 when I already have $350 of it.
Anyone ever run Tundra's with the Cornfed 1" spacer with LC coils?
Any other ideas would be more then appreciated. Thanks.
Old 08-12-2007, 08:07 PM
TRDrunner's Avatar
within the next couple of days im going to run a 1.5" spacer with my tundras.
definatly do the diff drop with the spacer and the tundra coils.
Old 08-13-2007, 02:34 AM
Nate08's Avatar
Would you mind to post some pics so I could see how level yours is with the spacers?
Old 08-13-2007, 08:36 AM
TRDrunner's Avatar
yeah when i install them ill throw a couple pictures up.
and you might still rub on the frame at full turn with 285's and the sock wheels.
Old 08-13-2007, 04:43 PM
frodin1's Avatar
You shouldn't need to do anything. The only rubbing I had with my 285's was prior to the Tundra/890 lift " I had the 2.5"spacers" and it was on the running boards. After I took the die grinder to and took off a .5", Yes a 1/2" on the very inside it didnt rub at all. With the Tundra/ 890 there is no rubbing at all. The only thing I would suggest is making a bracket for your rear brake line if you havent already. You dont need any of that stuff to clear your 285's. My rig is a Limited and I didn't do any of it. I would do all of it if your going any taller though! Spacer= Diffdrop =LC's= Panhard bar= brake line.
Old 08-13-2007, 04:45 PM
frodin1's Avatar
Here's a pic with the 285's and tundra on my rig.
Old 08-13-2007, 04:52 PM
frodin1's Avatar
I do believe that you will start really jacking up the geometry of things if your planning on running the Tundra/890 with an 1.5" spacer, even with the diffdrop spacers, which you should be running with your Tundras anyhow. You should just go with a body lift if you want more height. Check out RooRrunners rig.
Old 08-13-2007, 06:17 PM
Nate08's Avatar
You rubbing at all? Whats the backspacing on those tires?
Old 08-13-2007, 06:27 PM
frodin1's Avatar
No, It's not rubbing at all, not even with the wheel cranked all the way. With your rig I wouldn't even worry about it, you don't have the flares or running boards. It used to barely rub when I had the 2.5" spacers on, and thats when I trimmed the 1/2" off the inside of the boards. But that was it. Even then it barely rubbed.The wheels are 16X8 6-5.5 x4"BS
Old 08-13-2007, 06:54 PM
Nate08's Avatar
I have the "bushwacker" flares. I might just end up running it with the topout spacer and some new wheels with that magic backspacer number.
dumpster84
04-30-2016 06:03 AM
jerusry
10-19-2015 05:28 PM
colasurdo
07-17-2015 11:29 AM
HaydenConQueso
07-12-2015 05:22 PM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: Hows this setup?
