How Much Play is normal in front CV Shafts?
I noticed today that the front passenger side cv shaft will slide back and forth (from diff to wheel) about 1/2 to 3/4 inch when i grab it and move it back and forth (in and out of the diff). Drivers sides seems to only move 1/8 inch. Is this normal?
John
John
I seem to have more play in my passenger side as well. That sounds a little extreme though. If it's a recently installed cv, bring it back and even say it's clicking, should replace.
yeah - this just seems wierd - the entire shaft moves in and out about 1/2 inch...like inside the boots. Went wheeling last weekend and got on it a little hard in one spot when my locker switch wasn't working. This is an aftermarket CV. Hmmm. Gonna take it into the shop - the suy who hsa replaced both my cv shafts said that's not normal at all...
If you are talking 1/2 not 1/8th, then you have a problem. Locker problem in most cases should not relate to the CV. Aftermarket CV or not, they all die young.
But it was a lifetime warranty axle so - it's free replacement.
John
Well, I'm saying i was in a tough spot and since my locker wasn't working, I had to use a little more throttle than i would have needed if i was locked - so therfore i think i spun the wheels and heard a lound bang - but didn't think it was a CV as it wasn't ripped open and spewing grease like I've seen others.
John
John
Flying91
45
04-11-2024 04:39 PM
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
01-10-2016 10:18 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
Hamonacracker
07-17-2015 08:33 AM
