How to clean a motor and things to consider for an optimal tune up! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-19-2007, 09:27 AM   #1 (permalink)
semo's Avatar
I have a 98 Toyota Tacoma Truck, Sr5 4x4, Can anyone help me with:
Tune Up Tips, I am going to take a Off Road and want to give my truck a full tune up.
How to clean my motor its full of mud!
Thanks a lot and Happy Holidays!
semo is offline
Old 12-19-2007, 09:29 AM   #2 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
seafoam.....for directions on great seafoam usage...see HERE.
Also, plugs, wires, oil, flush the radiator, air filter, oil filter, fuel filter(? up to you?), and go ahead and change the tranny, t-case and diff fluids.
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 12-19-2007, 02:51 PM   #3 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Plugs wires do not need replacement with the coil pack setup.
Here's what I do whenever I buy a used car. (some stuff that doesnt apply to a tacoma left out) As a mechanic, I'm a little anal on maintenence. This would be a good full tune up for you.
Change oil and filter.
Change spark plugs. Apply SMALL amount of anti-seize to the threads, and add some di-electric grease to the inside of the boots.
Flush and fill coolant (full flush, remove drain plug on block and run hose through radiator)
Flush brake fluid and power steering fluid if its dirty (optional for you)
Change front and rear diff fluid, and the t-case fluid if its a manual trans
Drain and fill trans fluid if its dirty. (auto trans)
Replace PCV valve
Clean out throttle body with carb cleaner and rag. Then do a seafoam treatment.
Top off windsheild wiper fluid (important if your 4wheeling)
Check/clean/or replace air filter
Check the front brake pads for wear. Clean brake parts off with brake cleaner
Check rear brake shoes for wear. Clean brake drum and shoes with brake cleaner.
Replace the fuel filter. They are like $25 at Walmart or more at the dealer.
Run a bottle of fuel system cleaner in the gas tank.
Grease your drive shaft. Get EVERY zerk. All other grease fittings on chassis should be sealed and not need grease, but if you do have a greaseable tie rod end or something, grease it.
Also before every offroad trip, I do the following:
Jack the front end up and wiggle the tires up and down and side to side to check for ball joint play and steering play, or wheel bearing play.
Grab your tie rod ends and make sure they are tight.
CLOSELY inspect CV shaft boots for cracks and leakage.
Re-tighten ubolt nuts
Re-tighten drive shaft nuts
Grab driveshaft and check for side to side and rotational play.
(if you have manual hubs) check hubs for smooth lock/unlock operation
Lock hubs, put in 4wd, and make sure 4wd works properly
Your safe to clean your motor at the carwash with a high pressure hose. Just be careful and dont apply too much pressure to sensitive electric parts or hoses. If its really muddy, I'd first do a quick pressure wash to remove the loose mud, then go back over it with a soapy brush by hand. Then a good powerwash.
Adam F is online now
Old 12-20-2007, 03:35 AM   #4 (permalink)
onesojourner's Avatar
spray some degreaser on the motor a few times before you wash it.
__________________
98 4x4 limited 4Runner, e-locker, 4.30 gears
onesojourner is offline
Old 12-20-2007, 05:03 AM   #5 (permalink)
FWIW - I would use Throttle Body Cleaner on the TB, not Carb Cleaner.
__________________
Great Toyota Tech
Old 12-20-2007, 05:20 AM   #6 (permalink)
Bighead's Avatar
Cleaning the engine bay:
I usually go to the local car wash to do this. I leave the motor running and spray the engine compartment with Simple Green. I let it sit about 5 minutes and then use the spray wand to rinse it off. I do not squeeze the trigger on the wand for the high power blast...I just use that low pressure stream for the rinse job. After that, I drive home and let the engine dry for a while. The last thing I do is touch up any missed spots and spray all my rubber and plastic engine parts (not the belts) with 303 Aerospace Protectant
__________________
Lance
2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000
2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers
Bighead is offline
Old 12-20-2007, 05:43 AM   #7 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
[quote=Bighead;50699882]Cleaning the engine bay:
I usually go to the local car wash to do this. I leave the motor running and spray the engine compartment with Simple Green. QUOTE]
ouch! im not really too sure your supposed to spray your engine while its running... for fear of shorting out the alternator or messin something up.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 12-20-2007, 07:12 AM   #8 (permalink)
People say that but I was told, by my dad when I was young, to leave the car running. Always have and never had a problem with anything. Just don't use the full pressure and you should be ok.
That's up to you though.
__________________
If it has tits or tires it'll give you problems.
98 4runner - SR5, 4x4, 5 speed
The Probe, CJ5, G20 and Porsche are all sold.
Right now everythings a 4x4 or 6x6. MRAPs, 916s, HMMWV, FMTVs and anything else with amror.
pkt1213 is offline
Old 12-20-2007, 08:02 PM   #9 (permalink)
Adam F's Avatar
You wont have problems with leaving the engine running and spraying it off. And if your careful, you wont have problems with using the high pressure blast.
But cleaning a muddy engine compartment is different than cleaning a dirty engine compartment. Even if you spray degreaser on it and spray it off, it will still leave a muddy film after it dries. Only way to get it off is to clean it with a cloth by hand.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What / how to clean the inside of bell housing & back of motor? SuaveGato 86-95 Trucks & 4Runners 10 07-18-2007 06:34 PM
Taillight, RR Wiper motor, WIndow relay, Turn Switch, Sunroof motor 99 4Runner SR5 DeathCougar The Classifieds GraveYard 5 03-24-2007 12:33 PM
3vze Motor Questions..Poss Motor Swap!?!? mburg28 86-95 Trucks & 4Runners 6 09-14-2006 09:35 AM
summer tune: Clean you stuff sefus 95.5-2004 Tacomas & 96-2002 4Runners 0 04-10-2005 07:14 PM
305/70/R16's What's the optimal back spacing? TStango 95.5-2004 Tacomas & 96-2002 4Runners 3 07-19-2004 08:01 AM
2009 InternetBrands, Inc.
