Here's Nose Drive Bearing Part Numbers (1st gen S/C)
Old Apr 25, 2004 | 10:51 AM
yoda-g2's Avatar
Post Here's Nose Drive Bearing Part Numbers (1st gen S/C)
Just an FYI for all the do-it-yourselfers out there:
Instead of just shelling out $170 for a remanufactured nose drive, I figured I'd do a littel research. I assumed that all a new nose drive was, is an old one with new bearings and seal, boxed with some special gasket compound and oil. So I decided to bite the bullett and tear mine a part to see what could be done. You see, we have a local bearing shop that has every bearing ever made, so I figured that odds were in my favor.
After pulling it apart this is what I found:
UPDATE:
Front Bearing P/N: NSK 6204 ($3.71)
Front Oil Seal P/N: CR 7965 ($3.25)
Rear Bearing P/N: NSK 6303 ($6.27)
Lockrite Gasket Maker: ($6.00) - Anaerobic - 'for aluminum'
*4oz S/C Oil: ($7.00 )
*Any GM parts dealer, Info courtesy of Magnuson.
TOTAL cost for complete nose drive rebuild...PRICELESS (Under $30.00)
I actually got Koyo replacement bearings, I'll UPDATE with the proper cross reference P/N's later today.
UPDATE:
It looks like the model numbers are the same for Koyo and NSK, like somebody else mentioned.
I hope somebody else can benefit from this info, Enjoy!!
Old Apr 25, 2004 | 05:02 PM
Albuquerque Jim's Avatar
Awesome, are the bearings pressed?
Thanks!
Old Apr 25, 2004 | 09:04 PM
yoda-g2's Avatar
Yup, but with a socket, an BFH, and a little TLC, you can tap them out no problem. We didn't bother using the press, I just get nervous when I can't tell how much pressure is where, just imagine cracking that aluminum housing :pat:
Old Apr 25, 2004 | 09:29 PM
toy283's Avatar
Koyo uses the same industrial standard bearing numbers as NSK. It should be a 6402 as well.
.... just imagine cracking that aluminum housing :pat:
Then you're back where you started. No big deal (except to the wallet). It's not like it's an irreplaceable, out-of-production part.
Old Apr 26, 2004 | 03:39 AM
MTL_4runner's Avatar
You could even have one machined up if you cracked the original.
Might cost you a few $$$ though.
Old Apr 26, 2004 | 08:31 AM
yoda-g2's Avatar
Yeah, it wouldn't be the end of the world if something happened, you'd just lose your core deposit. I just wanted to point out that you can still do this yourself even if you don't have access to a press. That might scare some people off from trying it.
Old Apr 26, 2004 | 02:04 PM
Great info Yoda-g2! You should do a full write up with pics.
Mike
Old Apr 26, 2004 | 03:50 PM
Mike
I agree totally!!!!!
Please help us all out and do a writeup and submit it to Corey for posting in the tech section.
Old Apr 27, 2004 | 09:12 AM
yoda-g2's Avatar
I updated the part and price info.
:pat: Ok, don't hate me, I didn't have my digi cam when I took this all apart, and now it is nicely installed on my S/C, which is on my rig... :pat: I should've thought about a write up. Sorry I'm not worthy to be a YT member.
To redeem myself though, if someone is thinking of doing this, they can mail me their nose drive and I'll happily do the swap for them, and do a write up. Any takers???? Mine was a 1st gen S/C, but I assume that the 2nd gens should be just as easy.
Let me know!
Old Apr 27, 2004 | 02:15 PM
Gadget's Avatar
Good work!
What is a good source for the seal?
Gadget
Old Apr 27, 2004 | 02:32 PM
toy283's Avatar
What's so special about this oil? My supercharger uses standard 75w-90 gear oil.
Old Apr 27, 2004 | 05:12 PM
yoda-g2's Avatar
Judging from the looks of the oil, 75w-90 would be WAY too thick. Magnuson, the company that makes the S/C, recommended only using the specified oil for it. I believe that it is a special full synthetic blend, but I can't say for sure.
Originally Posted by Gadget
Good work!
Gadget
Thanks, the seal is from a local bearing specialty store, I don't think they do internet ordering though, I could act as a middle man if anyone is interested in purchasing some.
Old Apr 27, 2004 | 06:13 PM
Gadget's Avatar
Some superchargers use engine oil. Some use gear oil. Some are tapped into the engines oil system.
The Eaton superchargers have a sealed gear box and they use a special synthetic oil that has about the same consistancy as water. The GM dealer is the best cheapest place to get it from.
Gadget
Old Apr 27, 2004 | 09:19 PM
Plus, the smell from this SC oil will keep you coming back for more.
Old Apr 27, 2004 | 09:20 PM
PS For anyone interested, I did a write up on how to change the nose drive without removing the SC. Do a search on my name and nose drive to find it.
Old Apr 28, 2004 | 06:56 AM
elnip's Avatar
yoda-g2,
Great info! Thanks for the effort
Old Apr 28, 2004 | 08:57 AM
bbeast's Avatar
no luck
mhawker, I searched YT forums and came up with one hit and it wasn't your write-up. This was on a 1st Gen S/C - I'd have to see it to believe it.....
Old Oct 27, 2007 | 11:56 AM
Davies's Avatar
I know this is an Old thread..... but does anyone know if replacement bearings and replacment numbers are the same for the 2nd Gen S/C as for the first? I'm about to replace my bearings in my 2nd Gen (makes a bad bearing sound) and wanted to use these part number references...
Old Jan 15, 2010 | 09:03 AM
spaugh's Avatar
bump, i have a 2nd gen with 115K miles on it. I want to replace the bearings before they go bad. Anyone know if the part numbers are the same?
thanks
Old Jan 15, 2010 | 12:50 PM
akaphilly's Avatar
i dont have the part numbers but theres some ppl on ebay who sell the complete kit. decent price. with everything needed
