help wiring apexi rev/speed meter
does anyone know how to wire up the apexi rev/speed meter on the 2003 toyota tacoma double cab v6. i pretty much need to know the tachometer and speedometer wire on the ecu
Tach Wire: TOYOTA, TACOMA, 2003, Tachometer
On the 4 cyl it is also at the data link connector to the right of the steering column. On the V6 it is also at the igniter on the passenger fender, below the air filter box.
Color: Tachometer lt. green/black
As for the speedo, I can't help you there, sorry.
Hope the Tach helps you out though!!
Brett
Brett
