HELP! Truck wet inside after rain. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-25-2005, 06:54 PM   #1 (permalink)
cstary's Avatar
We've had some heavy rains this past few months, and the carpet in the back/bed of my 1999 4Runner is SOAKED after it rains. I have no idea how it's getting in. I don't drive the truck much, so it's not getting splashed in. There is nothing drilled into the roof, and the rubber looks completely intact on the doors and tailgate. The floor and the headliner are dry . . . it's just the very back, behind the rear seats.
Any suggestions would be greatly appreciated!
creed
cstary is offline
Old 02-25-2005, 07:10 PM   #2 (permalink)
wrenchmonster's Avatar
Get a buddy and a hose and try to find out where it is coming from. Do you have a sunroof by chance? If so, check it well and make sure the drains are clear. You may have to remove some interior panels to find your leak. Also, just like a metal roof on a house, your leak may be in the front somewhere and traveling all the way to the back. Good luck.
-Wrench
wrenchmonster is offline
Old 02-25-2005, 07:15 PM   #3 (permalink)
cstary's Avatar
good idea - i'll pull off the paneling and try the hose technique. i do have a sunroof.
thanks man!
creed
cstary is offline
Old 02-25-2005, 07:26 PM   #4 (permalink)
Sure no windows were open?
socal98runner is offline
Old 02-25-2005, 07:38 PM   #5 (permalink)
WT
WT's Avatar
Do you have a factory roof rack ?? remember a while back a few have had leaks around the ends and it was making the headliner wet too, is yous wet ??
Also check around the tailgate to be sure all the weather stripping is in place.
Good luck ....
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2|
WT is offline
Old 02-25-2005, 07:52 PM   #6 (permalink)
Steveh29's Avatar
I had this problem once. There are vents on the back edge of the rear quarter window. These vents are supposed to let air blow out but not let water and stuff in. They're mainly used when the climate control is set to 'fresh air' and not 'recirculate'. You can turn on the air full blast on fresh air and close all the doors. Then walk back to the rear quarter window and you'll hear air blowing out. For me, tiny leaves got in there and plugged up some drains. Back end carpet got wet every time it rained. I had to pull the rear quarter window to clean it all out. So that's another place to check. You can pull the inside panels off and see if water's coming in around the window.
__________________
Steve
1995 4Runner - V6 - 5 Speed
Rear ARB, Manual Hubs, Front TruTrac, Marlin Transmission, ARB Front & Sonoran Steel Rear bumpers that have saved my life!!
Steveh29 is offline
Old 02-25-2005, 08:33 PM   #7 (permalink)
cstary's Avatar
thanks for the suggestions, guys. i do have the roof rack, but i think the headliner is dry. i'll check the rear air vents and windows ASAP.
THANKS!
cstary is offline
Old 02-25-2005, 08:37 PM   #8 (permalink)
4-RUNNIN' FREAK's Avatar
CST. I had water get in mine and everything was sealed tight. It rained so freaking hard once that the water either worked it's way through the rear window or somewhere else and pooled a little on the cargo cover. Never did find the source. And this was AFTER the 12 sheets of* Second Skin on the roof.
__________________
'02 4Runner - '06 XRunner
Breakdancing
www.BadgeYourRide.com
Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/
Highest Xmax 6.5" subwoofer made
Total Posts: 32,218 (75.35 posts per day) [/center] [/color]
Still A Neon
4-RUNNIN' FREAK is offline
Old 02-25-2005, 08:44 PM   #9 (permalink)
Steveh29's Avatar
4-Runnin' Freak has a good point. We've had so much rain here on the West Coast that some could have blown past seals. For me I knew it was a problem because it leaked EVERY time it got wet. Even in a light rain. Pulling the inside panels will show you if water has been leaking down in areas. Good luck!
__________________
Steve
Steveh29 is offline
Old 02-25-2005, 09:25 PM   #10 (permalink)
I wash my truck with a pressure washer sometimes, and never had the problem though. The rain was so heavy is sounded like hail. I am wondering if it can actually rain harder than what a high flow pressure washer can push out and into things.
__________________
Breakdancing
Still A Neon
Old 02-25-2005, 10:19 PM   #11 (permalink)
cstary's Avatar
it was really soaked in the back - i don't think it was because of the unseasonal weather - there must be something wrong causing the leak.
cstary is offline
Old 02-25-2005, 10:42 PM   #12 (permalink)
WT
WT's Avatar
Quote:
THANKS!
Water still could be coming in behind the head liner and running down the sides to the carpet without making the head liner to wet, so may want to check that area when your testing with the hose thing ..
__________________
WT is offline
Old 02-26-2005, 12:51 AM   #13 (permalink)
CSTARY? you have a sunroof/moonroof by any chance?
__________________
Breakdancing
Still A Neon
Old 02-26-2005, 08:11 AM   #14 (permalink)
cstary's Avatar
Quote:
yes i do
cstary is offline
Old 02-26-2005, 10:14 AM   #15 (permalink)
yes i do
If you don't think you can find the leak, it probably won't hurt to check there too. Maybe water is somehow running along the hose and dripping off to a point on the headliner and then making everything all wet. It would depend on how you are parked too, on a hill, flat.
EDIT: I am trying to give you a picture, but it's not working. There are hoses that are in the truck to drain the sunroof. Maybe AT the point where the hose slides on, water is slipping through and travelling alond. Make any sense?
__________________
Breakdancing
Still A Neon
Old 05-02-2005, 03:10 PM   #16 (permalink)
arrrgghghh im having the same problem, and i think i ruined my amp.
i park on a hill, (front higher than rear) and recrently ive been getting tons of water on the rear wheel well, on the passenger rear side and under the passenger seat. all seals look good, it has a place for a roof rack, but none ever installed, the headliner looks good, there is standing water in the rear cargo space passenger side.
arrrgh.
toy_yoda is offline
Old 05-02-2005, 03:12 PM   #17 (permalink)
BTW, its a 96 SR5 with everything but leahter.
toy_yoda is offline
Old 05-02-2005, 06:43 PM   #18 (permalink)
CoedNaked's Avatar
also try things like the taillight assemblies. These are things that can cause leaks on other Toyota vehicles (happened on a Tercel that I owned into the trunk).
__________________
1993 Xtra Cab Pickup | 4x4 | 3.0 - V6 | R150F | Silver-Grey | Amsoil 10w30 synthetic oil | Amsoil Synthetic Drivetrain fluids|
Borla Cat-back Exhaust | OME HD Leaf Springs | Bilstein HD Shocks | Downey Idler Arm Brace | Grey Husky Liners | SR5 Bucket Seat Swap | Color matched Canopy | Yakima racks | Line-X OTR | Michelin LTX A/T 31 x 10.5 x 15 | 323,600 KM's (202,250 miles) | Made in Japan - Vin starts with "J"| Fish on
CoedNaked is offline
Old 05-03-2005, 02:13 AM   #19 (permalink)
mine seems to be coming from the rear passenger door, it may be leaking in the rear as well though, cause its wet in the back too...
just recently started, none of the rubber looks gone, but it doesnt look new either...
im gonna try and do a water test as soon as itll stay dry around here for more than a day.
toy_yoda is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
HOT after long trip inside truck!? Yota Beave 86-95 Trucks & 4Runners 7 07-09-2007 09:22 AM
Smelling fuel inside truck? RabbitX77 86-95 Trucks & 4Runners 5 02-19-2007 02:35 PM
3rd Gen truck - wet okole impressions. bryanr 95.5-2004 Tacomas & 96-2002 4Runners 8 09-09-2005 05:16 AM
what to do in the rain? acid_burn Offroad Tech 8 12-03-2003 06:46 PM
Tag sugestion for my truck..pic inside Kerr Off Topic Talk 17 07-18-2003 01:09 PM
2009 InternetBrands, Inc.
