Help needed: rear lower control arm reattachment
Installing my rear 2" cornfeds (solo) and I thought, hmm...I'll get more space to work with if I unattach my lower contol arm....driver side, by the gas tank....so....anyway....need suggestions now on how to re-attach! Got the bolt on and 1/2 thru.
thanks,
aaron
thanks,
aaron
use a ratchet type strap or some rope . loop it around the axle housing and a point in front of the front mount. If your using the ratchet just tighten it up till the bolt hole lines up. With rope looped around and tied together put a screwdriver between the 2 lines and twist them together til the bolt hole lines up.
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
icentropy
07-14-2015 10:23 AM
icentropy
07-11-2015 07:21 AM
