help fuel pressure regulator
Old Oct 5, 2004 | 03:35 PM
rover1's Avatar
Unhappy help fuel pressure regulator
hi all
i think i have found my misfire problem when towing my boat (code 300 303 306 ) , i need to check my fuel pressure regulator how do you do this also i checked the vacuum line no cracks or leaks , but where it plugs in for a vacuum , at idle i feel no vacuum at all , also there is no engine rpm change when i un plug the vacuum line .
please note i have changed the plugs dealer plugs new wires , new fuel filter, had the injectors cleaned , i am thinking the vacuum for the fuel pressure regulator is not plugged in the right place. any one out there can tell me where it should be plugged in , now it is on the black box between the maf and the throttle body
Old Oct 5, 2004 | 03:53 PM
rimpainter.com's Avatar
Year/Model/Mileage??
Old Oct 5, 2004 | 03:57 PM
rover1's Avatar
2000 4 runner 100 k
Old Oct 5, 2004 | 04:17 PM
2.7 or 3.4?
Old Oct 5, 2004 | 05:03 PM
rover1's Avatar
sorry 3.4
Old Oct 5, 2004 | 06:17 PM
OK, yes, it is the black box (Intake silencer) halfway down your intake pipe. That is where it plugs in. If you follow the line toward the intake manifold, it will lead you to the FPR.
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
v_man
Jul 23, 2015 04:01 PM
Poppie51
Jul 16, 2015 06:16 PM
