Help - Engine won't turn over
Got in the truck to go to work and the engine just kept cranking and cranking and would not turn over. It's not the battery, and I don't think its the starter since it sounds like it is trying to crank it just fine. If I try to crank the engine for about 5 seconds, the cranking automatically stops. Anyone know what could be my problem?
Dave
Dave
What you posted doesnt' make sense. How could you be cranking and cranking but the engine isnt' turning over. If your engine is seized your starter is going to make some horrific noises. I think what you mean is it turns over but will not fire maybe? Please specify.
Senior Member
Mine has been having the exact same problem, but then I will let it sit a couple of seconds and it will fire right up. It has done this to me twice in the last 3 months. I'm not really sure what it could be either.....
I noticed this with my truck too. Someone told me that if you turn the key to "on"(without starting the truck) and let it sit for a minute, is starts up better. Worked for me
steve miller
10-10-2015 01:40 AM
