YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-08-2008, 11:18 AM   #1 (permalink)
Rock Slide's Avatar
Lightbulb Hella 4000s converted to HID
I wasn't sure where to put this thread, so I dumped it here. Mods, move it if you feel it does not belong here.
Let me start off by giving thanks to Bruce on UY for the great write up on this mod. I would have never thought to do this, had I not seen his write up first. (For more information on his install, check it out here: Click Me)
Having sold my previous set of IPFs, I’ve been on the hunt for another pair of lights for my TJM. This time, I wanted a bigger, brighter light than I had before. I tossed around the idea of Hellas, KCs, Lightforce’s & even HID Hellas. However, once I came across Bruce’s thread, the decision was made easy.
I opted for a set of Hella 4000s. These are 8” round, 100wt halogen lights with the Cornering Beam pattern. I chose this pattern over the Driving Beam pattern simply because I wanted a wider light spread. I got a deal on the lights and picked up the set brand new for $150. The Hella wiring harness is sold separate, but since I already had an existing wiring harness from my previous lights, I was able to reuse what I already had. I also purchased an inexpensive 35wt HID kit off ebay for around $75. It is a H1 kit with 4300K bulbs.
Picture of the HID kit I purchased. Please note, this is just a universal picture of the kit I used. I used H1 bulbs.
Install was very easy. I removed the lense from the housing and simply removed the stock 100wt halogen bulb:
Next, I inserted the new HID H1 bulb:
Like Bruce, I also drilled a hole in the back of each housing to accommodate the new HID bulb. I decided to leave the stock-wiring plug in place in case I ever decide to convert these lights back to a halogen set up. Therefore, I just covered up the existing pin connections with tape and zip tied it off.
With the bulbs installed, I sealed the grommets with black RTV silcone to further prevent water from leaking in through the new holes.
I sealed each ballast to prevent water from entering. I disassembled each one and placed a bead of silicone inbetween the top and bottom covers. Once the covers were reinstalled and the silicone had dried, I wrapped each ballast in tape. I also siliconed both areas of the ballasts where the wires plug into it.
To mount them, I just zip-tied them in place. I may ditch the zip ties and upgrade to hose clamps in the future, but for now, this works.
(You will also notice I have 4 ballasts mounted…the other 2 are wired for small fog lights that I’m in the process of adding.)
Lights mounted. I also added a set of clear covers to the lights to protect the lenses:
Darkness was approaching, but here they fired up:
That night, I took a few more pictures of them:
Approx 10ft back:
Approx 40ft back: (And yes my headlights are still on. I will say that the camera deceives you a little though. In this picture, both lights are on, but it appears as though only one is. From this distance, I could clearly make out both lights even though the camera could not. Although, if I looked at them too long, I could not see anything afterwards. They are very bright):
On the trail with just my headlights on (photo taken thru the sunroof):
Same spot with just the Hellas on:
Notice the ridge in the background…that is approximately 300ft away.
I'm digging these new lights. The light output is amazing. With this Cornering Beam pattern, the light spread is almost a complete 180 degrees and reaches very far out on both sides. I could not stand back far enough to get a good enough picture to show the side-to-side light spread, but believe me, it is WIDE.
Now I can say I officially own a pair of Hella HIDs
I'll post a video soon of them warming up...it's really cool to see too.
__________________
2002 4Runner Sport 4WD
My 4Runner Profile
Accessories: SS 7.1 Lift Kit, WabFab 1" BL, TJM T15, Stubb Sliders, FX/TSX HID Headlight Retrofit, 1st Gen Rollbar, Tundra Brake Upgrade, Hilux Surf Field Monitor, TRD I.S. Wheels, Nitto TG 265/75s, Hella HID 4000s, Tint, Black Pearl Emblems, Clear Corners, TRD Decals, JBL Door Speakers
Mods: Disabled DRLs, Disabled Keyless Entry Chirp, Disabled VTRAC/VSC/ABS, Fog Light Mod, Air Elbow Mod, Ashtray Mod, Mud Flap Mod, Rear Diff Breather Mod
Rock Slide is offline
Sponsored Links
To remove this ad, register today!
Old 05-08-2008, 11:45 AM   #2 (permalink)
Hirox's Avatar
Awsome work!
I always admire what you done well.
It makes me to buy one for my rig
looking foward to see your video.
__________________
'96 1KZ-TE DIESEL TURBO 3000.
Geolander M/T+ 285/75R16
Hirox is offline
Old 05-08-2008, 12:05 PM   #3 (permalink)
netwt12's Avatar
good work. you did a really clean install. War Eagle BTW.
__________________
2000 4Runner Limited 4x4 "TRD". Blown, etc.
1988 Trail Truck. SAS, Dual Cases, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash.
2008 Camry LE.
netwt12 is offline
Old 05-08-2008, 12:28 PM   #4 (permalink)
Cool
So bright!!
As ever, professional install!!
__________________
Wanted: Square end caps for dark tan 4Runner cargo cover.
Wanted: 96-98 4Runner Clear bumper lights.
blarchitect is offline
Old 05-08-2008, 12:28 PM   #5 (permalink)
Tacoclimber's Avatar
Very, very cool! Great writeup!
__________________
CJ ...<><
03 DC TRD Tacoma 4wd with a bunch of junk.
Just wheel the stupid thing!!!
But do it responsibly, ok?
Tacoclimber is offline
Old 05-08-2008, 12:35 PM   #6 (permalink)
Sloan's Avatar
Quote:
oh please, not that crap lol
looks awesome though, the light output looks fantastic!
__________________
'01 Toyota 4Runner Limited
Mods Listed Here:My 4Runner
Quote:
Originally Posted by Corey View Post
Once must also realize that YotaTech has always been open to both 2WD and 4WD trucks and SUVs. This means the gnarliest off road rig, to the lowrider that scrapes its belly over a dime in a parking lot.
Sloan is offline
Old 05-08-2008, 12:51 PM   #7 (permalink)
Rock Slide's Avatar
Thanks guys...these lights really do turn night into day.
__________________
My 4Runner Profile
Old 05-08-2008, 12:59 PM   #8 (permalink)
Cxrazy's Avatar
That just inspired me to do this mod.
Thank you.
__________________
-Logan
Quote:
Originally Posted by Sold
1998 4Runner Limited - Anthracite Metallic - 265/75/16 Radial APR's - Cupholder Mod - Removed Pinstripe
2004 Tacoma - Xtra Cab - TRD - Rear Locker - 5 Speed
Cxrazy is offline
Old 05-08-2008, 04:05 PM   #9 (permalink)
pattycakes77's Avatar
Quote:
WOW! that looks like a train! i guess you won't have any trouble seeing where you're going and people won't have trouble seeing you
a nice, clean install as usual. it's all in the details
good job!
__________________
The PATYWGN: 1998 4Runner Desert Dune Pearl.
PATYWGN show-off thread
PATYWGN on Cardomain
Pattycakes77 on Myspace! let me be your friend... please?
Sport Hood FAQ
pattycakes77 is offline
Old 05-08-2008, 05:10 PM   #10 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
I have been planing to do this to my extra lights for some time, though i was going to use the Hella 500's. But i really like that beam battern of the 4000 cornering lights!
Before any of that though i need to get an SC!
__________________
Just call me TA
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck
All the Mods that can be done to 3rd Gens Thread
My thoughts on Gun control summed up quite nice:
Quote:
Originally Posted by sdstud212001 View Post
Guns kill people like spoons make people fat
Quote:
Originally Posted by Dare44 View Post
Im a firm believer in the saying "If you outlaw guns, only the outlaws will have them"
“Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns”
Texas_Ace is offline
Old 05-08-2008, 07:23 PM   #11 (permalink)
Rock Slide's Avatar
Quote:
Crazy aint it. You look head on at these lights at night and it will cause you to loose your vision momentarily. I know, b/c it happened a few times to me...
__________________
My 4Runner Profile
Old 05-08-2008, 07:36 PM   #12 (permalink)
Rock Slide's Avatar
Quote:
Originally Posted by Hirox View Post
Awsome work! Looking foward to see your video.
As promised...
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
__________________
My 4Runner Profile
Old 05-08-2008, 07:45 PM   #13 (permalink)
MARSHALLMAY's Avatar
I have been thinking of doing that for over a year now. The only reason I don't Is because HID bulbs burn out very quickly when they're switched on and off frequently. I'd love to have them for hi beams, and they do look awesome from the drivers seat. But that's alot of $$ for light bulbs.
__________________
We are the people bred, raised and nurtured to maturation to live life in the pursuit of acquiring status-ensuring product in a never ending pilgrimage to find value in ourselves through the indulgence of materialism...gotta love it
oh yea, 98 4x4 ltd for sale
MARSHALLMAY is offline
Old 05-08-2008, 08:13 PM   #14 (permalink)
Cxrazy's Avatar
Quote:
Originally Posted by Rock Slide View Post
As promised...
YouTube Video
Where'd you get the arc reactor?
__________________
-Logan
Cxrazy is offline
Old 05-08-2008, 08:35 PM   #15 (permalink)
Fo_SheeZy's Avatar
Looks amazing, you should upgrade your headlights though, are they stock?
__________________
Check out my 2008 Urban 4Runner on CarDomain!!
http://www.cardomain.com/ride/3108855
http://www.myspace.com/bmplayar
Hella 500's FOR SALE, PM me!
Fo_SheeZy is offline
Old 05-09-2008, 03:27 AM   #16 (permalink)
Jdizzydub's Avatar
Man was tinkering with the thought of how to do that with my 500's...that totally gives me the idea. I do like the beam pattern better on those 4000's, that's just awesome! Was looking at that same kit on ebay, too.
That picture head on is super bright, and as said before looks like a frickin train,lol.
Nice work!
__________________
97' 4RUNNER SR5 4x4
Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, OME LC Rears
2in. 4crawler BL, SS Diff drop, Custom welded drop bar
Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod
Wheels & Tires:315 16x9's on MOTO METALS
Lights:Silver Reverse Glow Gauges, Hella 500's
Armor:Trailgear Sliders, Taco ARB
"Sounds stupid. . .sign me up!"
Jdizzydub is offline
Old 05-09-2008, 05:59 AM   #17 (permalink)
Rock Slide's Avatar
Quote:
Let me just say I'm working on an upgrade for those too
__________________
My 4Runner Profile
