headlight connector positive, ground connectors
Old Nov 26, 2004 | 12:48 PM
Amir904's Avatar
does anyone know on the headlight connectors (looking at it straight), which one is positive and which one is negative, there are 3 connections, one on top, and two on either side of it. im trying to replace my HID system with another and it requires me to figure it out myself, i can do it with a voltmeter, but its broke.
Old Nov 26, 2004 | 04:32 PM
Flamedx4's Avatar
You sure you have HID, and if so who put it in? If the factory plugs and wiring are intact, this should help:
File Type: pdf
Old Nov 26, 2004 | 05:18 PM
Amir904's Avatar
ya they are HID, but the connection that i am supposed to make to the factory 3 prong connector is supplied but the wires are not hooked up. it is a black and white wire going to the ballast. if u look at your diagram, on the bottom right is the connector, thats the connector i am not sure about, the location of the black and white wire.
Old Nov 26, 2004 | 09:06 PM
Gadget's Avatar
The headlights on your truck are reverse ground.
When you switch them on a relay sends power through what normally would be a ground on a normal system. Then another set of relays allow the different beams to ground to turn them on. This would normally be the positive side on a normal system.
If you lights are on and you meter any of the three wires on the plug all three will give you 12+.
You can get one of those waist of money head light harness upgrades from SUV lights. That will convert the headlight plugs over to a normal type that you can plug stuff into and have it work normally.
Gadget
Old Nov 26, 2004 | 09:08 PM
jimbo74's Avatar
gadget, you dont liek the upgrade light harnesses? why not?
Old Nov 27, 2004 | 05:32 AM
Amir904's Avatar
so i can plug in the black and white wire for the HID into any of the 3, and it should work? but what happens when the high beams come on?
Old Nov 27, 2004 | 09:21 AM
MenaceSQL's Avatar
If you look at the connector as like what you said, the top connector will be the low beam (-), the left connector is the high beam (-), and the last connector on the right is the positive. This is according to my '89 negative switched truck that uses a H4/6054 connector like your '98.
To answer your question, if you have your HIDs hooked up to the positive and the low beam negative on the factory connector and then turn your high beams on, the HIDs will turn off. You can do this and everything should be fine but if you "flash" someone, my guess is that the HIDs will come on too.
okamikai
Apr 30, 2018 10:19 PM
bvleonov
Aug 22, 2015 11:39 PM
msged2007
Aug 22, 2015 07:46 PM
nonstop
7
Aug 11, 2015 09:26 AM
TDonkey
Jul 26, 2015 10:14 AM
