hard start after fueling
Old 10-28-2008, 01:33 PM
mudjunky's Avatar
Hey guys I have an 02 taco with 148k. The other day I got gas and the truck didnt want to start at the pump, finally with a little throttle it started and ran crappy for a minute, after that the truck ran fine until I got gas again. same thing happend. I also got a check engine light po171 at the same time.
I have tried taking off the fuel cap and it will start and run fine, its just when i refuel. thanks for the help
Old 10-28-2008, 02:35 PM
YoterUp's Avatar
clogged fuel lines fuel pump fuel filter. start with the cheapest and work your way up
Old 10-28-2008, 02:36 PM
sharrack's Avatar
Are you topping off more than usual?
I'd stop topping off for starters IF the no start condition is truly linked to fueling up..
Kenny S>
Old 10-28-2008, 03:21 PM
mudjunky's Avatar
I changed the fuel filter, no difference. I dont think it is a clogged line, because the problem is only when I gas up, not really sure though. Im thinking when I fill the tank the gas it triggering some sesor an it is making the system lose its pressure, because when I turn the key I dont even get a spudder like there isnt even gas at the fuel rail. I appreciate the feedback, I really want to figure this out.
Old 11-06-2008, 03:32 PM
mudjunky's Avatar
It ended up being the pwm vacuum switching valve. I changed it, no more check engine, and she likes the gas again
Ichneumon
09-27-2015 04:21 PM
bigblue82
10
07-06-2015 08:27 AM
94 Newbie
07-06-2015 04:23 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: hard start after fueling
