Hands Free Car Kit Install HELP!
Old 07-06-2004, 07:31 AM
wynndi's Avatar
Q: Has anyone installed a CARK-91 kit in their 4Runner? I need to know where to tap ignition/power/ground. It's for a NOKIA.
My 4Runner is a '96. Thanks!
Old 07-06-2004, 09:07 AM
User 051420's Avatar
I'm not exactly sure this is the correct way, but you could theoreticly tap into the radio's wiring. Check this, it's a PDF wiring diagram: http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
Let us know how it works out!
Old 07-07-2004, 07:36 AM
wynndi's Avatar
Thanks! I may go that route if I can't find a similar installation!
Old 07-07-2004, 11:16 PM
Morr's Avatar
That's the way to go, I recently installed a Nokia car kit in my '96 Surf (4Runner) and used the feeds to the radio, works perfectly.
Old 07-10-2004, 08:06 AM
wynndi's Avatar
Before I tear into the dash.....what's the best way to access the connector I'm tapping into? Do I have to remove the radio?
Old 07-10-2004, 04:00 PM
Morr's Avatar
Another page from the site gapguy listed above should sort you out, at http://www.installdr.com/InstallDocs...PDF/869017.pdf you'll find full directions for gaining access to the area you require.
Old 07-11-2004, 03:18 AM
MTL_4runner's Avatar
Check out my alarm install pics in my signature.....you get some good shots of tearing into the dash behind the radio.
bigjstang
08-25-2021 12:41 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Hands Free Car Kit Install HELP!
