gotted scanned today 4 codes pull up
Old 06-07-2013, 05:20 PM
burton6509's Avatar
about 6 months ago cel light comes on...p0440 and p0446 come up fine out i need to replace my charcoal canister but i dont really need to fix it until i need a e-check and every once in awhile the cel light would stay off for a bit...then i notice it wont so i go to autozone and get scanned and the same 2 show up with c1201- abs engine control system malfunction. latley ive notice that when i pull into a parking space or a gas pump my abs will kick in. only happens with speeds under 5mpg... the other code was c1340- open circut in center diff lock signal.
what should i do? should i pay 100$ to have the dealer look at it? or could i try and do it myself? anyone know the price it would be to fix?
Old 06-07-2013, 05:56 PM
j2the-e's Avatar
The 1201 code simply means that the computer sees a problem with something else that may affect the abs operation. When the other issues are resolved, the abs code will not return. I have replaced a few of those center diff lock actuators. I would start by clearing the codes and checking the operation of the 4wd system. If you need an actuator, it could be well over $1000 to replace. They are actually not too terribly difficult to replace however if you can follow a manual
Old 06-08-2013, 03:32 PM
burton6509's Avatar
Thanks for the info....How do you clear the codes?....disconnect the battery?
Old 06-08-2013, 05:23 PM
j2the-e's Avatar
Don't think that will do it but you can try. I honestly don't remember how to do it without a scanner. Maybe someone else will chime in or maybe some searches will yield results
Old 06-08-2013, 10:58 PM
wyoming9's Avatar
Red face
Yes disconnecting the negative terminal will work leave it off for at least 10 minutes.
If you plan to work on the newer vehicles a OBD II code reader that can erase is well worth the money a scanner even better.
Some of the codes will shut the engine off
the FSM with the diagnostics makes it so much easier.
Regency
20
01-03-2020 07:43 PM
viesail
07-06-2015 10:16 AM
CJ94yota
07-03-2015 10:14 PM
Corey
06-25-2002 08:39 PM
Yoda
06-23-2002 09:39 AM
Quick Reply: gotted scanned today 4 codes pull up
