GEN 3 Switched 12v tap?
Old Oct 2, 2004 | 06:31 AM
Beach-Rat's Avatar
I'm re-doing the first owner installed items on the '96 by adding a "painless wiring" (homemade) switched sub-fuse panel…
Oh great Gurus, where is the best place to pick up a switched 12v control lead?
I have searched under the hood and dash (without disassembly) and nothing “jumps out at me.. Am leaning towards the 15 amp accessory fuse but I can’t locate drop side access outside of the harness..
Ideas? What has worked for you?
Old Oct 3, 2004 | 04:08 AM
MTL_4runner's Avatar
As long as you are not drawing any large amperage you can use on of the 2 switched sources under the dash by the ignition switch. You can look at the pics of my alarm install which also have wire colors and supply so you know what to look for.
If you are going to draw some amps I suggest you set up your own source by using a relay to switch it on when the car is on.
Old Oct 3, 2004 | 05:59 AM
Beach-Rat's Avatar
Thanks.. Had hoped not to have to drop the dash shirts..
Picture of a real Painless.. the switched 12v only runs the relay..
http://www.offroaders.com/jeepfan/pwcb.htm
Old Oct 3, 2004 | 07:02 AM
Sorry, I meant to say to use the relay and then "trip" the relay with the switched 12V under the dash.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Mrhoadley
Aug 4, 2015 06:08 PM
JAMGarcia
7
Jul 31, 2015 11:46 PM
Johntom240
7
Jul 13, 2015 12:18 AM
razorman8669
Jul 12, 2015 12:13 PM
