Fuel pump fuse?
Old 06-15-2003, 02:07 PM
NHTacoma's Avatar
Fuel pump fuse?
Hi everyone. Changing the fuel filter on my '99 Tacoma 2.7 and I want to depressurize the system by running the engine with the fuel pump fuse out. Which fuse does the pump run through?
Thanks,
Tom
Old 06-15-2003, 02:17 PM
TDiddy's Avatar
The Haynes manual shows a fuel pump relay in the cab. Just remove the trim panel that runs under the steering column, and you can unplug the harness form the relay.
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Fundy Rider
07-16-2015 01:35 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Fuel pump fuse?
