Front tire alignment issue?
Old 10-12-2005, 03:06 PM
4Runna's Avatar
Hi all,
After washing my 4Runner this past weekend, I noticed something odd when looking at my grill from about ten feet back. My front tires weren't perpendicular to the ground. They looked like this:
\-----------/ (though not as severe)
Then I got my tires rotated and they said that the outer edge of my tires had slightly more wear than the inner edge.
Is an alignment going to do the trick here?
Thanks in advance...
Old 10-12-2005, 03:09 PM
Flamedx4's Avatar
probably nothing wrong. A slight \----/ is correct.
https://www.yotatech.com/forums/f2/t-bars-down-not-up-69195/
and many many others...
Old 10-12-2005, 03:21 PM
4Runna's Avatar
Thanks Flamedx4. You just saved me some $!
Old 10-13-2005, 02:13 PM
surf4runner's Avatar
check out the ball joint recall for later 4runners.
Old 10-13-2005, 02:56 PM
jimbo74's Avatar
also it could be an alignment issue... no way to tell without checking it first.... if the alignment is out, then doing an alignment will fix it....
it depends on the spec for that vehicle, some of the high performance bmws actually are in spec like / \ they purposely set the tires @ 1-2 degrees negative camber for handling
Old 10-13-2005, 03:32 PM
4Runna's Avatar
I have a 1998 4Runner Limited. I just read up on the recall and it doesn't look like it applies to me.
However, the slight angle of the front tires is bugging me to the point where I must have them "fixed". It may be within spec, but I want them []----[] instead of slightly \-----/
thanks tho!
BushPig
10-29-2022 06:26 AM
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
87blyota
07-08-2015 09:16 AM
Quick Reply: Front tire alignment issue?
