Fluid Changes/Maintenance
On a 3rd generation 1999 4Runner with only 2WD, what types of fluid changes do you recommend?
I have routinely done the following:
(1) Engine oil and filter change
(2) Automatic transmission oil flush
(3) Brake fluid flush
(4) Power steering fluid flush
(5) Coolant flush
What are the other types of oil/fluid changes/flushes do you folks recommend? Thank you.
(5) Coolant flush
What is the best type of halogen fluid and where can I buy a lot of it?
Will it improve gas mileage? Will my engine run smoother, faster? I need more RPMs! Will it produce a lot smoke when I use it? Because the more smoke the better it works.
I think I got plenty of fluid in already, but I want to do it anyway.
