first timing belt/water pump replacment
Old 09-01-2012, 08:21 PM
forrest232's Avatar
Ya I have a 1/2 inch drive set, made things easier. But man torquing that bolt down is tough I just couldn't get torque wrench to click. So I'll just start fresh tomorrow
Old 09-02-2012, 12:43 PM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
^for that, i used a 4 foot piece of aluminum (possibly steel) pole that slipped over the HUGE 1/2 drive wrench. that long pole achieved the leverage needed for 217 ft/lbs MUCH easier. i think it was just an old chain link fence post....
Old 09-02-2012, 04:30 PM
forrest232's Avatar
Unhappy
Ya well somehow I managed to crack my crank pulley trying to torque it down. Called my work and its list price is 520. But thankfully I only have to pay cost + 10% but its still going to run me about 270, I have no idea how it happened.
Old 09-02-2012, 04:55 PM
kball's Avatar
That sucks! The only way I see that happening is if the woodruff key got cocked and you torqued the pulley against it. ??
Old 09-02-2012, 06:16 PM
  #25
rworegon's Avatar
Where did it crack at? Was it the holding device you used that cracked it or the bolt itself? I know they crack pretty easily if dropped.
Old 09-02-2012, 06:24 PM
  #26
TheDurk's Avatar
Originally Posted by TheDurk
Can't help you there. Mine just slid off at 120k. I will advise they break easily and cost a lot.
I warned you!
Old 09-02-2012, 07:31 PM
  #27
forrest232's Avatar
Yes I heared your warning loud and clear but it happens, it was the pulley its self that had cracked I guess too much torque with setup. I'm frustrated that nobody carries it so I couldn't put it back together today soo I'll have to order an oem one from work at least I don't have to pay an ARM and a leg like some people
Old 09-03-2012, 08:29 AM
  #28
Mordgier's Avatar
If you're willing to wait a week or two, I should have a spare as I'm replacing my engine. I can't be the only one sitting on a spare pulley, I'd ask around before buying new.
Old 09-03-2012, 01:14 PM
  #29
TheDurk's Avatar
I know. I just wanted to show off my warning. That sucks. Please tell us exactly where it cracked. If it's on the backside kball is probably right. There is only about 1/4" of key that comes out from under the sprocket that has to go into the pulley. If that key isn't in there and just bears on the pulley, I'd guess it turns the whole thing into a nutcracker when you torque the pulley down on to the point of that key. I would have thought it would just mash the key, but once you get it to high torque on the bolt that nub of the key will still crack the pulley.
Old 09-03-2012, 02:20 PM
  #30
forrest232's Avatar
Where it actually crack was through the center where the 3/8s hole it cracked straight through. Never seen or heard of this where the lil key is, is fine must have been a poor casting or something.
Old 09-04-2012, 08:32 PM
  #31
4Tard's Avatar
A paint pen and an impact gun work wonders for retorquing the crank bolt. I have never and will never bother with some unwieldy tool to hold and possibly damage the crank pulley.
Old 09-05-2012, 06:12 PM
  #32
forrest232's Avatar
Yup well I learned my lesson, boss gave me a decent price for 250 like 10 over cost or something. But definitely an expensive mistake. From now on I will just be using a good old chain wrench.
Old 09-05-2012, 06:44 PM
  #33
rworegon's Avatar
Not my method of choice, but to each their own.
Old 09-05-2012, 06:48 PM
  #34
forrest232's Avatar
Ya that way doesn't sound the best to me...now my favorite is chain wrench easy and works well!
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
85run
07-08-2015 11:20 PM
B. Graves
07-03-2015 04:10 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: first timing belt/water pump replacment
