First start engine squeak
If you want to find out what is squeaking on your truck you are just going to have to start taking things apart. I am betting fan clutch also, but the belt needs to come off & you need check the resistance of your fan clutch & get a feel on your pulleys for a bad bearing.
it's not a matter of if it's turning or not, it's a matter of is it turning at the same rpm as the motor. You can clearly hear the fan speed up after that noise goes away.
#25
Try this, for giggles. If the fan clutch is not engaged, it can be stopped with a rolled up newspaper. Try and hold the fan at startup, carefully and in a way that will not hurt you and see if you have the chirp with the blade not spinning. I think this will tell you a lot about what is going on, or at least rule out the clutch as part of the problem. It WILL engage shortly after startup, so be careful.
Aleeex_u
06-05-2016 06:52 PM
Ladythump
07-04-2015 03:35 PM
