Last edit by: IB Advertising
- Toyota Tacoma How to Install Trailer Hitch<br>Step by step instructions for do-it-yourself repairs.
Finally painting my trailer hitch
Alright, my stock trailer hitch is getting worse and worse...everytime I look at it I say to myself, "this needs to be painted." Well, I've been saying that since I got my 4runner. It's time to do it, but first I need to figure out the most durable way to paint it.
I will probably use a heavy duty wire brush on it to get all the residual crap off of it, and then if necessary use my hand grinder to get off the stubborn rust that is on it. Is there anything else I should use? Probably shouldn't use a solvent or anything since that may get into the metal and keep the primer/paint from sticking.
What kind of paint would you recommend, I was originally gonna get it power coated since a new PC shop just opened down the road a ways from me but I figured I could just buy a new trailer hitch for the amount they would charge. So what would you guys recommend as far as brand/type of paint. I know I will need a metal primer, but then I need to decide if I want to paint it matte black like it is now, or a glossy black to match the finish of the Runner. Then I will probably put some kind of clear coat on it.
Any ideas are welcome!
Thanks guys,
Fink
Thanks guys,
Fink
if you use por 15 remember that it is affected by UV, so when you put it on its best to put a coat of paint over top or else it will fade to white if it is in a place that is open to sunlight.
I dont know how expensive it would be, But how about bed liner? Either diy or Rhino, diy would be cheaper and would last if you prep well enough. Something I need to do, that and paint the wind deflector, its really discolored.
Edit: If you used bedliner, make sure you dont get it inside the square receiver, or on top of the mounts, the hitch might not fit properly then.
Definately POR-15 for the initial prep. Stuff works killer. I would go with Line-X for the final coating. The franchise you go to should be well aware of the mounting points and hitch hole to keep the spray off. I just had my rack lined and it was well worth it. They spend extra time prepping it and making sure the seal would be top notch. I need to do the same on my '95 4R.
Yeah I could do that but, now that I have taken the hitch off I really like how the rig looks without that huge bulky hitch back there...I am thinking of looking into getting a hidden hitch or one that is not so noticeable.
So, if I were to go that route I need some suggestions! Definitely the less noticeable the better and preferably something I could drill holes to mount the little connector housing that Toyota has on the stock hitch, I love that feature!
One reason I want to do this is for looks, but another is because one of the bolts that holds the connector housing on was completely broke, the top of the bult just twisted right off with minimal amount of pressure applied, not sure how I am going to get that out and salvage the threads in the whole. But mainly its just to get it out of the way.
So...ideas on hitches! Thanks guys!
Fink
Fink
Found this one online...what do you think? Is this the kind that is mainly hidden by the bumper? If so, doesn't seem like a bad deal. I'm sure I could drill into this hitch and figure out a way to mount the connector housing.
What do you guys think???
http://www.etrailer.com/productdetai...rfrom=1999&h=e
EDIT: I forgot to post this link, rocket pointed out that the above unit is a copy-cat version of Hidden Hitch, looks like the one below is the one I should get huh? Opinions please!!
http://www.hidden-hitch.com/products...&model=4Runner
Fink
Fink
LoL, OK, found another one...this one says it requires drilling but it seems likes as far as visibility this would be the way to go, says that it tucks out of sight pretty easily. Anybody have any ideas on how much drilling would be needed?
LoL, so feedback on both of the ones listed above would be great!
Thanks,
Fink
Thanks,
Fink
1 Post
Yeah definately do the POR 15 kit. You will get Marine Clean degreaser, Metal Ready which is a rust remover and etcher that helps the paint adhere, and the POR-15 paint. Make sure you take precautions to avoid getting the POR-15 paint on your skin as it will stay there until the layer of skin naturally dies. I had it on my skin for over a week before it came off.
Once you do the POR-15 system you will NOT have to worry about it rusting again and you can do whatever you want on top of that (Be it bedline it, powdercoat it, what have you).
Make sure you follow the POR-15 instructions and it will be permanent.
http://www.hidden-hitch.com/product...&vehicleid=2591
That DrawTight you linked is a copy-cat of the original 'Hidden Hitch'. Every time i see a hitch that looks "good" and is well hidden, i'll take a closer look to see who made it and 10 times out of 10 its HiddenHitch.
Not only that but after comparing the two, i noticed the H.H. weighs less, is the same price, and has equal tow ratings.
If it were me, i'd go with the H.H. anyday on any vehical.
Any opinions? The one in the first link is apparently a copy-cat model so I don't think thats what I want. The second link is a genuine Hidden Hitch design, should this be pretty easy to install?
Any ideas are helpful, I need to get this rolling because I'm going camping this weekend and bringing all my bikes and 4-wheelers and need the trailer.
Thanks guys!
Fink
Thanks guys!
Fink
Fink, trust me and just get the Hidden Hitch. Its easy to install and you wont be disapointed.
Just some FYI: I use to sell trailer hitches at Tractor Supply Co. ...that is why i look at ones that look good.
Thanks guys!
Fink
Thanks guys!
Fink
AG
Yeah but I can't see how that would work with this particular hitch, I mean, if you flipped it, the brackets would be hanging down too low.
Sounds like I'll be ordering the Hidden Hitch...thanks for all the advice.
Add more comments if you'd like, I won't be ordering til tomorrow.
Fink
Fink
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
Jcrawl94
10
10-24-2015 04:34 PM
dropzone
08-11-2015 05:16 PM
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
08-04-2015 08:49 AM
defrag4
07-31-2015 10:50 AM
