a few questions with piston ring job
Old 02-06-2005, 07:23 PM
needayota's Avatar
hey all, i am almost ready to pull the engine.
i was wondering if there was any good tricks to do when pulling the transmission so i dont have to go out and buy a tranny jack. right now i have a really small floor jack from kragen for $20 and 2 jack stands. i know that a trans jack would be optimal but i dont have the money right now.
another question i have is about head bolts, rod bolts, and main bolts.
should i buy all of these from ARP/does arp offer these for the 22-re?
what should i replace when the engine is apart? (rod bearings, bolts, bushings, piston rings, etc.?)
anything special i should watch out for?(keeping #1 bolts and bearing with #1 rod and #1 rod with #1 piston?)
thanks all!
Old 02-07-2005, 06:18 AM
MTL_4runner's Avatar
thanks all!
For the tranny removal with a floor jack....
Here is the "right tool" approach:
http://www.cumminstools.com/browse.cfm/4,137.html
http://www.brandsonsale.com/transmis...pter-jack.html
Here is the "budget: approach:
http://www.acs.ucalgary.ca/~csimpson/Tech/TranJack.html
When doing the rebuild I would replace all bearings and seals, hone the engine cylinders and use new piston rings.
There is quite alot to doing a complete rebuild so it is very difficult to give it all in a concise answer.
A kit like this is helpful to ensure you have all the parts:
http://www.roadlessgear.com/Merchant...Store_Code=TOY
bigjstang
08-25-2021 12:41 AM
dumpster84
04-30-2016 06:03 AM
thefishguy77
07-30-2015 10:59 AM
TDonkey
07-26-2015 10:14 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Quick Reply: a few questions with piston ring job
