Fender Liner Removal? (if you like puzzles look inside)
Old 07-20-2004, 08:46 PM
Guest
4RUNR's Avatar
How do I take out this fastener? Can't figure out any way but brute force when getting at the back of it is impossible
Old 07-20-2004, 08:50 PM
BruceTS's Avatar
order up a bunch of new one's before taking out the liner, then simply break out the old ones. If you want to save them then get a few different pairs of needle nose pliers to push in the 2 tabs that keep them held in, It's a PTIA but I've done it.....
Old 07-20-2004, 08:57 PM
Guest
4RUNR's Avatar
How did you break them though? They are pretty sturdy in relation to the fender liner, and are flush with the surface.
Old 07-20-2004, 09:02 PM
Bob_98SR5's Avatar
Agree with Bruce, just buy replacement ones.
I busted them open with a drill
Bob
Old 07-20-2004, 09:16 PM
Guest
4RUNR's Avatar
They are not like $9.95 a piece are they?
Old 07-20-2004, 09:37 PM
85RedRunner's Avatar
If those little flanges push in you can slip a snug fitting closed end wrench over them. this will push the flanges in and you should be able to slip them right out. if those flanges are fixed and wont push back in i would just cut them out
Bob_98SR5's Avatar
4Runr:
When I removed mine, i drilled out two and then pinched the third one from the inside (because i had some hand room) and pulled it downwards. too much effort.
just drill them all out.
i can't rember the exact cost but i think they were under $2 each
bob
Old 07-20-2004, 10:07 PM
Birdman's Avatar
I would think a door panel removal tool would do a nice job snapping these buggers out. They will probably break but how else are you gonna get the little biiatches out?
Old 07-20-2004, 11:36 PM
Andrey's Avatar
Those fasteners are $.75 or so at Toyota. Not bad at all in my opinion...
-- Andrey
Old 07-21-2004, 03:51 AM
tulsa_97SR5's Avatar
On mine the liner was stretchy enough to pull them around the head of the fastener without removing it, but that was on the 90.
Old 07-21-2004, 04:14 PM
QIKRUNR's Avatar
Definately! Pull the liner over the head of the fastener carefully. Then you can get to the backside to push the tabs in and pull out the fasteners. Now you can re-attach the liner using the old fasteners. FREE is best! I do this on a daily basis, and haven't broke anything yet.
Old 07-21-2004, 05:36 PM
waskillywabbit's Avatar
Talking Buy NEW ones!
I got mine for like $0.67/each at the dealer. I just cut them off with a pair of snips or drilled them out until they busted. Be a cheap skate and reuse them by stretching the liner over them to get it off and you've done just that, stretched the liner, which can't be fixed. Get off your wallet and buy a big bag of them at the dealer, they have loads and fix your fender well lining RIGHT, not half !
My $0.02
EDIT: OR just rip the fender well lining out and forget about it period. The big popcorn size bag behind the glass counter is only $335.
Old 07-21-2004, 05:47 PM
Goldrunner's Avatar
Get the new ones, I screwed around with mine trying to get them out in one piece and did more damage than it was worth, it was a royal PITA and a waste of time.
Old 07-21-2004, 05:51 PM
Guest
4RUNR's Avatar
A big bag, ehh? I can already picture that popcorn sized bag under the glass at the parts counter for only $670.00
Old 07-21-2004, 06:14 PM
Yeah, looking at my new 97 tonight I'm thinking that on the 90 one of the previous owners must have streched 'em for me. They came right off on it, but on the 97 they'd take quite a bit of stretching.
Old 07-21-2004, 06:16 PM
fish's Avatar
why is http://208.186.61.11 (your server?) making my firewall freak out?
Old 07-21-2004, 06:17 PM
jimbo74's Avatar
im for trim panel remover....
Old 07-21-2004, 06:35 PM
Guest
4RUNR's Avatar
fish, it does? That’s a funny coincidence, I updated firmware in my router today.
Old 07-21-2004, 06:39 PM
Guest
4RUNR's Avatar
Ahhh fudge, when I brought it down somebody snatched my DHCP spot. So it's not me anymore heh.
09-04-2015 09:27 AM
JAmdor3
08-11-2015 10:53 AM
58rennur4
08-04-2015 08:49 AM
RustBucket
07-24-2015 04:46 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Fender Liner Removal? (if you like puzzles look inside)
