Fender Liner Removal? (if you like puzzles look inside)
order up a bunch of new one's before taking out the liner, then simply break out the old ones. If you want to save them then get a few different pairs of needle nose pliers to push in the 2 tabs that keep them held in, It's a PTIA but I've done it.....
If those little flanges push in you can slip a snug fitting closed end wrench over them. this will push the flanges in and you should be able to slip them right out. if those flanges are fixed and wont push back in i would just cut them out
4Runr:
When I removed mine, i drilled out two and then pinched the third one from the inside (because i had some hand room) and pulled it downwards. too much effort.
just drill them all out.
i can't rember the exact cost but i think they were under $2 each
bob
bob
I would think a door panel removal tool would do a nice job snapping these buggers out. They will probably break but how else are you gonna get the little biiatches out?
Definately! Pull the liner over the head of the fastener carefully. Then you can get to the backside to push the tabs in and pull out the fasteners. Now you can re-attach the liner using the old fasteners. FREE is best! I do this on a daily basis, and haven't broke anything yet.
Buy NEW ones!
I got mine for like $0.67/each at the dealer. I just cut them off with a pair of snips or drilled them out until they busted. Be a cheap skate and reuse them by stretching the liner over them to get it off and you've done just that, stretched the liner, which can't be fixed. Get off your wallet and buy a big bag of them at the dealer, they have loads and fix your fender well lining RIGHT, not half !
My $0.02
EDIT: OR just rip the fender well lining out and forget about it period. The big popcorn size bag behind the glass counter is only $335.
My $0.02
Get the new ones, I screwed around with mine trying to get them out in one piece and did more damage than it was worth, it was a royal PITA and a waste of time.
why is http://208.186.61.11 (your server?) making my firewall freak out?
09-04-2015 09:27 AM
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
08-04-2015 08:49 AM
crashburnoveride
07-10-2015 06:39 AM
