Fairly new 4Runner owner- MPG Problems
Here's a link to a real world test from edmunds.com on gas saving tips, the biggest savings they noticed was in driving habits, slow down a bit and avoid hard acceleration.
http://money.cnn.edmunds.com/ownersh...2/article.html
I think the problem is the gearing. I just found out that my car has 3.909 gearing and had 225/75/15's stock. Now it has 265/70/16 so if I want normal gas mileage I would have to get 4.10 gears (not going to happen)
Does this all sound right? I am new to this whole gearing thing. I think I am just going to leave it the way it is and get 4.56 and 33's eventually.
16" - 4.10 and 265/70 is what I have on my '00.
I am trying to get to 4.30 and 265/75.
I get between 16 & 17 MPG. 19 highway. My MAF went out yesterday, just a couple hundred miles over 100,000......
We'll see if it changes now.
Mike
Mike
Hmmmm.... I am in a '98, and I am currently getting around 20-21mpg. I've got over 172k on the engine.
Although I am in the "city", Detroit is pretty rural compared to NY, LA, or even Chicago.
Mods I am running which may improve milage:
- Tornado. Yes, it does work. I was at 16 when I bought the rig, and took it up to around 18.
- Fuel Magnet (?. the magnet thing for your fuel line - it was a present).
- No spare tire. This improved the milage at least 1mile! I have a can of fix-a-flat instead (I hope i never shred my tires!!)
- Deck plate w/ K&N filter.
Also, I considered the pros and cons floating around the net regarding acetone, and decided that at the current gas prices, might as well give it a try.
I have tried adding couple ounces of acetone to the tank, and it does seem to improve milage about 10%. I am just too lazy to carry it around with me.
tdk.
tdk.
#25
Update:
Drove like a grandma this tank (never shifted above 2000-2500 rpms) and got 15.6 mpg. . . I cant imagine how bad it iwll be when i get 285's. . .
#26
While I have to agree that shifting earlier and driving slower does help you out, I would think that shifting at too low of RPM's can not be good for the engine itself. Maybe I am just being a noob.
I drive fast at times, but most of the time, out on the highways I keep it under 60, and I get close to 24 MPG (mostly highway, because thats mainly all Montana is).
I would definetly do some routine stuff if I were you. Is your truck running rough?
#27
Change the sparkplugs, both filters and all the oils, this should help increase your mileage. The first modification I did to my rig was go to BFG AT's 265/75-16, my mileage dropped to 15-17mpg, but the speedometer was reading more accurately.
#29
Do you have the v6 or 4cyl? I assume v6 but haven't read either way.
edit: i think the only 4runners with 3.9 gears were 2wd, my 97 5spd 4cyl came with 225/75/15 and 4.10 gears. When I went to 32" tires I measured my odometer off by 10% using gps over a 1000 mile road trip. Your MPG may not be as low as you think if you are running tires that oversized.
#30
How do you know it came with 4.1 gears? I have a fullsize 225/75/15 spare (some firestone AT tire).
If your problem really is the gearing and/or tire size then this calculation will be off.
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
