Old 03-30-2016, 02:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Air Intake and Exhaust Guides
Print Wikipost
Exhaust Questions for My 04 3.4 Tacoma
Old 07-10-2006, 05:58 PM
BOSTON4RUNNER's Avatar
Originally Posted by boraxman
Im running a 2.5 cat-back, mandrel bent w/ Magnaflow and havent noticed any power loss. Seems that I have also gained on top end
I agree with you
if anything you would pick up power on the top end and I highly doubt you would lose anything at all even at mid and low rpm
Old 07-10-2006, 06:33 PM
MaNiAk's Avatar
Well I really don't know what to say. Some say 2.25 some say 2.5 My muffler shop says 3.0. I have 3.0 after a 2.5 muffler and stock cats I feel I have enough restriction. I'm running a flowmaster 60 series and I really like how it sounds especially with the Jba headers. I wanted a deep tome which the 3.o gave me. It sounds so good I wand to put a video file up so everybody can hear it, but unfortunely I don't have a Digital video camera. But anyway, some guys are turning down past the muffler and they are happy with performance. My setup would be no different. IMHO I feel that running a larger exhaust makes no difference other than the ECU might not be able to calibrate properly so adding a piggyback might help. But again this is my opinion. I came to a conclusion, my mid and top end runs so well that mike my bottem end seem weak.
Old 07-12-2006, 10:47 AM
04 Rocko Taco's Avatar
past a certian point, a bigger exhaust does hurt your engine. you lose the scavenging effect. your engine pulses the exhaust, and each pules is pressurized and heated, and creates a vaccum behind it, and pulls out the next exhaust pulse, thus the scavenging effect that helps evaccuate the hot stuff out. As your exhaust gets larger, that exhaust pulse has room to expand and lose pressure, and it cools as it dpereesurizes, and as it cools, it gets much heavier, so now instead of each exhaust pulling the next one out, each exhaust pulse is having to puch the one in front of it, this in turn makes your engine push much harder to evacuate the same amount of exhaust. Which seems backwards, but its true, bigger is better, to a point of diminishing returns. 3.0 is just to big for a Taco. Period. Unless its Force Inducted.
tj884Rdlx
08-28-2015 12:04 PM
thefishguy77
07-30-2015 10:59 AM
94whiterunner
07-12-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: Exhaust Questions for My 04 3.4 Tacoma
