ect button on dash?
Old 02-25-2003, 10:24 AM
knemo77's Avatar
Question ect button on dash?
i just got a new rig and it didnt come with the owners manual....i have that on order and i cant figure out what the ect button means on my 2000 4runner limited 4wd.....please answer this for me its the only think left i dont know how to use...thanks
right bythe rear defrost it has power and normal...
Old 02-25-2003, 10:49 AM
rimpainter.com's Avatar
Next time try a search, or at least say you did, and then post the question. But no bigee.
I believe it stands for Electronically Controlled Transmission or something.
In power, it will hold gears longer, thus "more power" so to speak (its better for towing and spirited driving)
In normal, it will shift sooner, generally resulting in better fuel economy.
Old 02-25-2003, 12:39 PM
Robinhood150's Avatar
You can also check out the FAQ section for any of your other questions.
Steve
Old 02-25-2003, 01:40 PM
INsr5runner's Avatar
I'm pretty sure it makes it shift later. It keeps your truck in the lowest possible gear, therefor causing you to shift later. This is actually worse for fuel economy because you are revving higher, and in the low gears longer... correct me if I'm wrong...
Old 02-25-2003, 02:21 PM
I am correcting you because I think you are wrong.
Normal= Granny driving, better economy, does not hold a gear as long
Power= Aggressive, road-rage type driving, holds each gear longer allowing revs to go higher than normal.
Old 02-25-2003, 02:55 PM
Ok I see what's up.
I meant to say that in ECT mode, it shifts later. I see where I got confused! It just took me like 5 times to get what was going on.!
man I'm hungry....
Old 02-25-2003, 03:27 PM
Los Gatos?'s Avatar
I should get my ECT button steering wheel mounted. So I can hit it like NOS *click*....zooooooooom. (the zoom is the gas guage going down :rolleyes: )
** Oh yeah, and you guys (96 and INsr5)are kinda saying the same thing....hold gears longer = shift later...same thing....
Old 02-26-2003, 05:22 AM
Ok I see what's up.
man I'm hungry....
Hey no problem man! I get that way when I am hungry too. Besides it appears that you were saying the same thing anyway.
Old 02-26-2003, 05:24 AM
Great idea!
Maybe they will have a 4runner in "2 Fast 2 Furious" when it comes out this June with a steering wheel mounted ECT switch...
Longbed 90
03-11-2019 12:38 PM
VT2LAB
09-10-2015 09:36 AM
Highlander Giant
09-08-2015 06:46 PM
zz_denis
09-06-2015 03:43 PM
May-39
09-06-2015 01:05 PM
Quick Reply: ect button on dash?
