Dumb question about 15 inch wheels on a '02
Old 08-05-2004, 11:53 PM
Donovan's Avatar
I know benn asked before but will 15 inch wheels fit on a '02 LTD 4x4with the 16 inchers stock?? I'm just wondering due to the bigger brakes?
Thanks
Old 08-06-2004, 04:20 AM
ugadawg95's Avatar
also...correct me if I am wrong, but I think it is a 5 bolt pattern on 15" wheels and a 6 bolt pattern on 16" wheels. (i think)
Old 08-06-2004, 04:37 AM
schlopecki's Avatar
Thanks
They most probably won't fit due to the bigger rotor.
That was the case in 3rd generation 4Runners anyway.
Old 08-06-2004, 04:48 PM
Donovan's Avatar
Oh yeah it's a 3rd gen Thanks for the help.
Old 08-06-2004, 05:04 PM
Highland Runner's Avatar
It may depend on the wheels you have. When I had a Tacoma and hung out on TTORA, this was a common swap. If anything you may have to grind a small nub off the end of the caliper. I want to do this to my wifes Runner eventually because the 31" tires are much cheaper than the stock 235/75/16 tires, yet are the same outside diameter. Certain rims will swap with no modifications.
Old 08-06-2004, 05:06 PM
seaflea's Avatar
NOpe 15" wheels are also 6 lug pattern making it possible to fit the newer 16" TRD wheels on the older rigs.
Old 08-06-2004, 05:21 PM
Yep, you're right. All 4WD's Toyotas have the 6 lug pattern, and many other makes like Chevy will also fit Toyotas.
Old 08-06-2004, 08:01 PM
User 051420's Avatar
Question....When 4runner leave the factory with 15's (like mine according to door sticker), and then the port or dealer installed the 16's, do they also install the larger brakes? I think that was part of the package too....
Old 08-09-2004, 03:57 AM
ugadawg95's Avatar
well cool...I didn't know that. I stand corrected.
coffey50
07-28-2015 10:55 AM
KBar
07-13-2015 06:01 PM
Yotoder865
07-09-2015 07:51 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: Dumb question about 15 inch wheels on a '02
